Holding tank heater
jvowell1
I have a 1996 Damon Intruder. It came with holding tank heater. Should I leave it on all the time?
5 REPLIES 5
SeaDog_BRR
My new TT has tank heaters with are thermostatically controlled however there is a warning that says there must be liquid in the tank do not turn when tank is empty. I would think its the sam for a Class A
Greg aka SeaDog Ret Navy
2016 Flagstaff 26 FKWS TT
96 Winnebago Adventurer 34RQ W/SO (selling)
06 F350 6.0, Harley Ultra Classic ๐Ÿ™‚ 64 corvette ๐Ÿ™‚
Blaster_Man
Depends on the coach. Some are automatic and will come on when the outside temp reaches a certain temp...providing you have the furnace or Aqua Hot on. Otherwise, manually turn it on when the temps will be freezing.
2014 American Eagle
GordonThree
Recommended that you turn them off if it's cold but tanks are empty. Without water to cool the plastic, there's a chance the plastic could soften.
2013 KZ Sportsmen Classic 200, 20 ft TT
2020 RAM 1500, 5.7 4x4, 8 speed
K_Charles
What kind of heater. Our last trailer that electric tank heaters that wouldn't come on until it got cold and then they would shut themselves off if not needed.
Kayteg1
Will take it a while to decode "NWFL" but if you are near, we have 60F weather.
No worry about freeze.
My brother in Baltimore area got snow up to his deck railing, so that would be different story.
