Oct-24-2016 05:53 PM
Oct-25-2016 02:56 PM
old guy wrote:
I used only air one time. I did not use anti freeze and the next year I had leaks from water still in the lines. I winterized my brothers the other day, blew out the lines and put pink in and you can not believe how much water came out ahead of the pink. I always blow out the lines and follow up with the pink now. if you have a winterization kit on the pump it is now much more work to do it right.
Oct-25-2016 02:25 PM
Oct-25-2016 08:40 AM
DrewE wrote:Campfire Time wrote:
This is the reason I not only blow out the lines, I use antifreeze in them as well.
You're certainly welcome to do that.
However, I must say I am a bit puzzled by how you're less likely to forget to pump antifreeze out the low point drains than you are to forget to pump air out the low point drains when winterizing. Failing to do either one would seem to me to be approximately equally problematic.
Oct-25-2016 07:43 AM
Oct-25-2016 06:05 AM
Oct-25-2016 05:53 AM
Oct-25-2016 05:12 AM
Oct-25-2016 05:05 AM
sch911 wrote:
You did fine. The low point drains are one of the last things I open up while under air pressure. Did you remember to flush the toilet a few times?
Oct-25-2016 03:44 AM
Oct-24-2016 06:07 PM
