โDec-16-2016 07:18 AM
โDec-27-2016 01:56 AM
โDec-26-2016 05:16 PM
โDec-17-2016 07:42 AM
Isaac-1 wrote:
I find when viewing these topics that there is a certain diesel bias in many of the replies. So let me respond as a fairly new Class A gasoline motorhome owner who happens to be fairly pro-diesel over all and share with you why I bought a gas coach. By pro diesel I mean I own a diesel powered pickup truck and at least 5 or 6 pieces of diesel powered equipment, and commonly deal with several others including medium duty diesel trucks.
1: I wanted a small Class A, most diesel Class A's are rear engine 32 ft minimum, and many of those have balance issues. Of the few front engine diesels that I considered, many had relatively small under powered diesel engines. The coach I ended up buying was also offered with 6.5L Chevy turbo diesel until 2001, I ended up buying a 2002 with the 8.1L Chevy Vortec gasoline powered version which has considerably more power than the 6.5 diesel 340 vs 180HP and 455 vs 385 torque, sure the gas engine revs higher, but when it comes down to it torque is torque.
2, My wife likes having a cool bed, and rarely uses blankets at night even in the winter, sleeping over a hot diesel engine would not be productive to domestic bliss for me.
3, The doghouse problem, I admit it can be an issue and I have owned class B camper vans in the past where the bulk and heat from the doghouse was a problem. Thankfully my Class A has a relatively low profile dog house compared to even the same model a couple of years earlier, so low in fact that I can walk across the edges of it without stepping up. And heat from this doghouse has not been an issue. Sure there is engine noise with a front engine, but there are things that can help here too, such as modern sound proofing products made by dynamat.
4, range, fuel economy and tank size, my 28 ft (well really 29.5 bumper to bumper) 2002 Safari Trek gets roughly 10 mpg and has a 60 gallon fuel tank so roughly a 600 mile range, personally I am never going to drive over 300-400 without wanting to stop and stretch so anything more would not make a difference to me. As to the tanks I have an 80 gallon fresh water tank, as well as a 40 gallon gray and 40 gallon black water tank, so not that much smaller than the lower end mentioned above.
5, Why do I need a 10,000+ pound towing capacity, I don't plan to pull a travel trailer around behind my motorhome, the 5,000 pound capacity I have is plenty for any TOAD I may buy.
Now sure there are downsides to my gasoline powered motorhome, most noteably the suspension, thankfully the previous owner spent over $2,500 addressing this and I have added another $500 getting it close to the point where I am happy with it and hope some new shock absorbers in a few months will get me the rest of the way.
p.s here is a comparison of a low profile 02 doghouse like mine vs the doghouse in a '97 Trek using pictures I found online
โDec-17-2016 07:29 AM
โDec-16-2016 07:40 PM
โDec-16-2016 05:00 PM
โDec-16-2016 10:05 AM
Diver4242 wrote:
...Excellent turning radius for the size of the coach (a 33โ DP will usually have a 208โ wheelbase and a 55 degree wheel cut and can turn around in a standard street)...
โDec-16-2016 09:19 AM
Diver4242 wrote:
I'm the OP. To clarify, that long list of gas/diesel pros/cons was from someone else in another thread. I included it for comment. What is meant by the "doghouse"?
โDec-16-2016 09:17 AM
โDec-16-2016 09:09 AM
โDec-16-2016 08:49 AM
โDec-16-2016 08:31 AM
โDec-16-2016 08:21 AM
โDec-16-2016 07:35 AM
Class A diesel pusher cons:
Limited inventory ?
Higher initial cost Higher trade in later
Higher cost per hour for service If you take off the better MPG savings cost, that may make it a wash
Typically more complex due to better integrated systems Nothing wrong with better
Limited floor plans (I only found a few floor plans that had bunk beds and a 10,000# tow rating) And you found more gas MH with a 10K rating? Recheck that info.
Click here to see where I am
