Diesel Genny cuts out with error Oil Temp-press!
smokey_truck
I am campin in VA beach area and when I turn on my Diesel Generator after 14 min it cuts out and I see this error in the panel Oil Temp-press!. This is 2013 Winnebago View with 12 Hours on genney. Checked the oil level it is between Min and Max lines
Does anyone have any idea with this, is it just adding more oil.
Thanks for any info
Ganesh
8 REPLIES 8
Dakzuki
Thanks for any info
Ganesh
You have a two year warranty on that generator. Unless you can easily fix it with more oil (up to FULL mark and not beyond...DO NOT overfill a diesel) and you don't know much about troubleshooting the issue go get it looked at by an approved warranty center. It could be just a failed sensor. My RV dealer said after the first year, take it to Cummins for warranty work when mine died. They took it in and replaced the failed fuel pump (which I had already diagnosed) under warranty.
2011 Itasca Navion 24J
2000 Chev Tracker Toad
tpi
I'd confirm it is level, then fill right to the max line before troubleshooting the level and pressure sensors.
Steele_Grey
I wish I could tell you what the issue is, but I have the same problem crop up frequently on my View with the diesel generator. I've tried various oil levels and different oils (including synthetics). The error does seem to happen more often when using synthetic oil.
It happens sporadically, but mostly at higher temps (90+). Sometimes the generator will run fine when in motion, sometimes it dies. Sometimes it runs continuously for 8 hours without a problem, sometimes it shuts down with no warning after 30 minutes. Sometimes it starts right back up and runs for hours, sometimes it starts back up and runs for 5 minutes (until I let it cool down).
I've gotten used to it, but I'm taking it to Onan before the warranty is out.
ryhed
Maybe leaning to one side causing a faulty oil level reading? Bad oil pump? bad sensor? Bare wire or bad connection?
smokey_truck
wolfe10 wrote:
What generator???
Onan 3200 Diesel
Ganesh
Old-Biscuit
My stand alone self contained gen would run then trip........Oil Temp/Press
Added just enough oil to bring level up to MAX
Ran (runs) fine.
Only thing I could figure was oil level dropped when started to trigger trip
wolfe10
What generator???
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
