Fumoto ValveAnyone who does their own oil changes, do you use this valve? On my F53 gasser, the oil plug is right above the front axle making it tough to get a pan directly under the plug and usually ends up with a mess. Not having to remove the bolt/plug each time and being able to put a tube on the drain valve would be very advantageous. Opinions?
1999 Holiday Rambler Endeavor, 36' Gasser
Triton V10, Ford F53 Chassis
