does not crank
Britches
I have a 1986 Ford E-350 motor home. When I turn the ignition on only sound is a brrrrr (for lack of a way to explain) I have seen this many times and has been a bad ground. I put in new positive and negative terminal cables with new terminal ends. ground to engine block. Charged the battery. It makes that noise and that is all. any advice would be appreciated
3 REPLIES 3
ronfisherman
Moderator
Moderator
Closed.
Please respond to this thread.
will not crank
2004 Gulf Stream Endura 6340 D/A SOLD
2012 Chevy Captiva Toad SOLD
DaHose
Is it a whirring sounds like a motor spinning or a clicking sound like a solenoid cycling?
Jose
BTPO1
Sounds like maybe the starter motor is turning, but the solenoid is not kicking the starter gear out to engage the gears on the flex plate or flywheel. JMO
Jack
2003 Rexhall Vision 27'
2019 Chevrolet Equinox
States we have been to with this MH
