DP - Apply Throttle for Cold Weather Start? (That Depends)
Rex_Haul
My owner's manual oddly doesn't cover Cold Weather Starting (20ºF or -7ºC or colder) but I found a general Caterpillar Winter Operation Guide that called for 1/3 throttle till start. Then a couple of minutes of low idle followed by 10-20 min of 900 RPM.
It's been several minutes since I wrote that first paragraph. In between, I called Caterpillar directly and got my answer. The answer depends on the model and year.
I've decided to share what I have learned because info is scare online and some of the YouTube videos I saw were just plain wrong, if not downright harmful. Get the facts for your motor from the manufacturer...
But in my case, a 2005 Cat C7 requires NO throttle and it's air intake pre-heater will come on for several seconds and I am to wait till it's light goes out - THEN crank the engine. The light may come back on while I am cranking. The light may come on or flash even after the motor has started if it's cold enough.
I'm told that it will take 10 seconds of cranking, at those temps, after a month sitting, just to get the fuel pressure up and so forth, before the engine will think about taking off on it's own. Could take 30 seconds before it takes off.
HOWEVER, if it's not running after 30 seconds, stop cranking and wait two minutes for the starter to cool before trying again.
Run the block heater for at least two hours prior, longer if colder than what I listed above.
Make sure your fuel is fresh, winter fuel, (min. 45 cetane) that you are using anti-gel, anti-moisture solution and your batteries are topped.
Ether can only be used on certain engines, specifically NOT on engines with air pre-heaters (Boom!)
There you have a timely summary of what to and not to do. Anyone care to expand?
To err is human
To RV is devine
11 REPLIES 11
Blaster_Man
JetAonly wrote:
Good list!
The only thing I 'd add as an observation is that I typically use block heaters below 40F. I know the manufacturers don't require it, but I like the ease with which they start. Minimum block heater time I use is 4 hours. If temps are below freezing I also use the engine heat function of the Aqua Hot. Typically, when planning a cold start I will use both all night. Doing this an I see 100F on the coolant temp in a few minutes.
Same here. When the engine block heater has been on prior to start, the "wait to start" light does not even come on since the coolant temp is always over 100 degrees.
2014 American Eagle
uncle_t
dsdp
I have been wondering why my voltage gauge hops around after a cold weather start. now I know and thanks.
2020 Integra 36U
can am spyder or can am commander
BE PREPARED- NEVER BRING A KNIFE TO A GUNFIGHT.
DSDP_Don
Here is something that sometimes throws people off. When cranking in cold weather and the intake heater is cycling on and off, you may see your volt gauge drop way off and then come back, The intake heater draws a lot of juice. People often think they're having voltage issues.
Don & Mary
2019 Newmar Dutch Star 4018 - All Electric
2019 Ford Raptor Crew Cab
RVUSA
you're doing the right thing. The main importance of block heating is reducing the chance of cold oil starvation. It doesn't splash well at all when it's the consistency of syrup and the cylinder walls need a lot of oil.
Along with poor splashing it is also hard to pump and the rod and main bearings can really take a beating if you run up the rpms before the oil warms up. Friction and wear really goes up if you hammer it cold.
JetAonly
Good list!
2000 Monaco Dynasty
ISC350
wa8yxm
Mike and Trish wrote:
You mean cetane, not octane. Opposite measures, more or less -- octane is a measure of resistance to pre-ignition (knocking), relevant to gasoline, while cetane measures combustibility, relevant to diesel engines. (These are rough definitions, which someone will undoubtedly correct me for.)
Id say close enough.
Octaine: Ability to RESIST ignition due to heat and compression
CETANE: Ability to IGNITE due to heat and compression,
That is how I leaned it, And you did say "Roughly", I'd have to use the same term to describe what I just typed.
In either case... THe poor guy either has typlexia (Which many of us have) or needs to re-read the O/P and notice it's a D not a G engine.
Typelexia happens when the fingers get ahead of the brain. (And recall flamers.. I did say "us" when I spoke of having it).
wolfe10
http://en.wikipedia.org/wiki/Cetane_number
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
Rex_Haul
Thank's folks, I have corrected my post.
In diesel you're looking for a cetane (not octane) rating of 45 to 55. basic diesel is 45, synthetic is 55.
To err is human
To RV is devine
Mike_and_Trish
Mike and Trish
2014 Thor Tuscany 40RX
2016 Jeep Grand Cherokee on Blue Ox Aventa LX
Yorkiepoos - Janis and Jimi
WyoTraveler
I think diesel is down around 45 octane. In my farm equipment I use #1 diesel or the additive to prevent gelling. Sometimes in the fall it gets cold before they start delivering#1 to my tanks.
Mike_and_Trish
Rex Haul wrote:
Make sure your fuel is fresh, winter fuel, (min. 87 octane) that you are using anti-gel, anti-moisture solution and your batteries are topped.
That 87 octane fuel might run funny in your Cat C7 ...
Mike and Trish
