Drumm or Disk brakes? Take a look.
userdan
I don't know much about brakes. Can you tell if my rear duallies have disk or drumm brakes.
1996 31'ft Fleetwood Bounder (Chevy P32 chassis)
Class A
This is a picture of the inside of the rear wheel from underneath.
Inside wheel
Bounder
24 REPLIES 24
userdan
Is there anything easy i can do to determine which without pulling the tires off?
ifd22
Looks like a caliber on the right, a glimpse of the disc in the center, and a dust shield on the left, I would say Disc.
2019 Primetime lite Crusader
2018 Ram 2500 Crewcab CTD
Andersen hitch
Peralko
Looks to me like disc brakes. You see the brake line enter the large metal object which should be what holds the disc pads. Right below that you see a break in the metal shield and you can actually see the dusc itself. We had a '91 Pace Arrow with the P-30 chassis, and it had discs all around. You may want to check them--our right rear disc broke off the shaft after a few years.
Peralko
USAF Retired
2000 Prevost Marathon H3-45
2006 Nissan Maxima
Old-Biscuit
What I see....
Upper hub assembly with gap between it and lower dust cover....Disc
jy
I,d bet they are disc brakes. If they are drum there would not be the large round piece where the piston is,and the wouldn,t have a flex line.
2016 wildwood bunkhouse,2018 f150 5.0.Camping with the grandkids now.
RayChez
It is hard to tell from that angle of the picture. It could be disc but just crawl under to see if you can see a rotor behind that plate that is shown on the picture. If it has a rotor, then you know it has disc brakes.
Also if it has a pan type looking drum, then you know it is drum brakes.
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar 3126-E
3000 Allison Transmission
Neway Freightliner chassis
2017 Buick Envision
Community Alumni
Not applicable
Inside I saw what looks to be a disc but after another look, it could be part of the rim so it's now looking like possibly a drum. That piece in between sure looks like a disc though.
userdan
Tried to post pictures directly to site but had trouble.
They are hosted at flckr through the above link.
Dog_Folks
Drum
Our Rig:
2005 Dodge 3500 - Dually- Cummins
2006 Outback 27 RSDS
We also have with us two rescue dogs. A Chihuahua mix & a Catahoula mix.
"I did not get to this advanced age because I am stupid."
Full time since June 2006
J-Rooster
Dan, I want to welcome you to RV.Net! I wanted to indentify the disc or drum for you but I couldn't see the picture you took due to preference settings on my computer!
