Aug-14-2014 09:48 AM
Aug-14-2014 05:29 PM
msmith1199 wrote:enblethen wrote:
Common?
You need to check to see what ducted outlets come off which AC unit. Yes, the bedroom one should only feed the bedroom, however it is possible that the duct from the bedroom unit may feed into hall or bath area.
Some thermostats or system allows the AC unit to switch automatically from AC units. This would allow the whole rig to stay cool, yet save energy by running only one at a time.
I can't speak for all ducted units, but all the ones that I've looked closely at (including mine) are all connected together. I can turn on my bedroom A/C and close the bedroom vents and it will push air to the front of the motorhome. I have done that before on hot days to get both units cooling the front. Also on hot nights I have turned off the rear unit and closed most of the front vents and let the front unit cool the bedroom. Makes for a quieter night without the A/C unit over your head running.
msmith1199 wrote:
You can't just assume running two units will cost more than running one. The opposite may in fact be true. Your goal is to cool the motorhome to a certain level. Two units will get you there far quicker and then turn off. One run may have to run twice as long to get you there. I have had units with both. My first Class A was a 32 foot with one unit and I took it to Vegas once in the summer. It was over 100 out and that one AC unit ran solid the entire time and still was unable to make the motorhome comfortable during the day. It was barely able to get us to a comfortable level at night.
Aug-14-2014 04:31 PM
Aug-14-2014 02:59 PM
Aug-14-2014 02:50 PM
Bumpyroad wrote:
on my RVs with 2 ACS I could run either one of them separately. could run both using EMS. that was one thing great about two units, could usually run the one in the area that we were not in, front one at night, etc.
bumpy
Aug-14-2014 02:33 PM
Bud
USAF Retired
Pace Arrow
Aug-14-2014 01:13 PM
enblethen wrote:
Common?
2021 Nexus Viper 27V. Class B+
2019 Ford Ranger 4x4
Aug-14-2014 01:10 PM
Aug-14-2014 11:15 AM
Aug-14-2014 11:08 AM
Aug-14-2014 11:02 AM
Aug-14-2014 10:59 AM
Aug-14-2014 10:57 AM
Aug-14-2014 10:20 AM
Aug-14-2014 09:55 AM
