Exhaust Leak on a 400 Cummins
SPRING_STREET
Can anyone tell me how to check for an exhaust leak on a diesel?? Have been hearing what sounds like an exhaust leak when driving with the window down on the highway. More noticeable when you have the barrier separating the lanes, and also when I use the engine brake. Had someone rev the engine when the RV was parked but couldn't find anything, so I assume it needs to be under a load. Also guess it may be in the Turbo if that's possible. Any comments appreciated !!
2011 MOUNTAIN AIRE 4344, FMCA F334596, Cummins Power Play,Good Sams and KOA member..TOAD 2017 Ford Edge Titanium with a 6 cylinder Engine, License plate "TOWED" > RoadMaster Night Hawk Tow Bar and Base Plates. 😉
14 REPLIES 14
CA_Traveler
A truck diesel shop should be able to do the repair. However, a truck only shop likely would not understand that this is your home or know what's involved working inside the rig. ie Dirty shoes, grease, etc.
So find a shop that understands MHs, including Cummins Coach Care shops.
2014 Grand Cherokee Overland
Bob
H_travels
What kind of business checks for Class A exhaust leak? Or name of business anyone has used and was satisfied with?
Ivylog
More than likely it's a cracked exhaust manifold on the larger of the two parts which is on the driver's side of the MH. You should be able to see black staining and on first firing the engine up you should be able to feel the heat from the leak if you cannot see it. Start soaking the bolts with PB Blaster now and you may be able to slow it down by putting a SS hose clamp over the crack until you can get it fixed.
Glad you found a better place to fix your alternator in two hours labor.
Upgraded with a 08 HR Navigator 45’...
koda55
When we had an exhaust leak they found the clamp for the S pipe at the outlet for the turbo was crooked. This allowed the pipe to not seat properly in the turbo. They reseated the exhaust and installed a new clamp. This cureed our noise. We also have the ISL 400 Cummins engine.
SPRING_STREET
Executive, I have the Cummins 400 ISL engine. Was at Cummins two weeks ago and had the computer put on it for an alternator issue. The only thing that came up was the alternator and low on anti-freeze which took almost 2 qts. They were told about the exhaust leak but nothing showed up and I had the alternator replaced elsewhere because of a 6 hour difference in labor !
Executive45
Black soot is the tell. Surprised your engine check light hasn't come on...maybe it's only a matter of time. You don't say what engine you have but Cummins can hook it up to their computers and tell you in a minute where it is. Meanwhile, check the vacuum line running to your exhaust brake for leaks....Dennis
Snomas
Mine showed black soot in the engine compartment.
2006 WINNEBAGO ASPECT 29H Ford E450 Super Duty
2018 F150 Lariat Crew Cab, Coyote 5.0 L RWD
Scottiemom
Ours was fixed this summer as Teacher's Pet mentioned. I first noticed it when we had fumes in the bedroom whenever we would stop for lunch or for the night. So next day before we left, he pulled up the inspection panel in the rear bedroom and I fired the engine. He immediately saw where the leak was. :E
Dale
Dale Pace
Widow of Terry (Teacher's Pet)
Traveling with Brendon, my Scottish Terrier
2022 Honda Odyssey
2011 Mazda Miata MX-5
2021 Coach House Platinum III 250DT
Fulltimed for 15 years, now living in Florida
http://www.skoolzoutforever.blogspot.com/
hsteinle
The Cummins 400 ISL has a KNOWN problem of developing a 'leak' in the manifold area around 60,000 miles. It would be best to take it into a Cummins shop and have them check to be sure you do NOT have that developed leak as it CAN cause serious problems including fires.
Harlan
Mesa AZ/Durango CO
’07 Alfa So Long Gold #4322
Cummins 400 ISL
Toad:
-Harley enclosed "Toy Carrier" cycle trailer, or
-‘01 Jeep Wrangler, or
-'11 Ford Explorer Limited
wolfe10
The "look for black soot" IS the correct way to identify an exhaust leak on a diesel.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
SPRING_STREET
OP here, Also wanted to mention that my exhaust comes out the right side and the noise sounds like it's on the left side and I do have the side radiator on left side
Teacher_s_Pet
Ours is a Cat 350...had a leak fixed this summer. Elbow from exhaust brake to muffler, 1/2" hole under heat shroud, new pipe + labor $340.
'06 Phaeton 40' QSH
'14 Ford Flex SEL AWD Toad
'04 R-Vision Trail-Lite 213
Scottiemom's Pet or husband to Dale
RV.net Rallies 13, Other Rallies 21, Escapades 7
Fulltimers since 2005, Where are we?
Our Travel Blog
rav
we had one on ours, same as you, heard it driving with the window open- I felt around the exhaust pipe (cold) and finally found the leak under the heat shield sleeve.
ScottG
Look for black soot marks emanating form the manifold and onto the side of the head. Most likely in the rear third of the manifold. Also look for cracks on the "ears" that the mounting bolts go through.
