nccrowley,
What you found out is what I've been telling folks for years. And that is, attempting to clean the radiator and CAC on SOME of these coaches IS almost a waste of time, if they're left in the coach. You see, as you've found out, the conditions at which those two units live in, are tough. The dynamics of how things are lodged into the fins of both, are such that, attempting to clean them FROM THE SAME DIRECTION, plain just doesn't make sense. All you're doing is forcing the dirt/debris/leaves/animals/plastic bags/oil and more, farther into the fins.
I've pulled the radiator and CAC out of our coach, an '04 Itasca Horizon 36GD with the C-7 330HP CAT, twice now in 7 years. The first time was right after we purchased it, right at 6 years ago. I had a radiator leak and, upon inspection with an inspection camera, I found that the radiator was about 50% clogged and the CAC was almost the same. So, out came both of them. At that time, it took me about 6 hours 'cause I was not speed wrenching at the time. I'm retired and I could care less how long it took me.
Before I decided to toss that radiator, it took me an entire gallon of Zep, citrus based degreaser and three passes with a pressure washer to get it clean. You should have seen the road grime/tar/dirt/oil/bugs/leaves/ and anything else that came out of those fins. On our coach, there is absolutely ZERO possibility of cleaning either of those two units while in the coach.
Some folks have some luck cleaning theirs. On mine, IMPOSSIBLE. So, fast forward a few years and, recently I had to do some major maintenance on the front of that CAT C-7. A fan bearing, belts, new water pump, CAT's "Regulators" (us normal folk call them thermostats) all the hoses, and a few other odds and ends while I was in there. But, that radiator and CAC took me right at 3.5 hours this time. It helped that I was familiar with where all the fasteners were at and how hard it is to get to everything and developed short cuts.
Well, that was 40,000 miles since the first R&R and while my slobber tube has been extended all the way to the rear of the coach and, I always install the correct amount of oil anyways, I still had debris in mine. It's inevitable. I modified my radiator frame so it would allow for maximum amount of air flowing through it. Before I did that, the frame had gussets at each corner that were solid. Not good.
Anyway, as for Winne and Itasca and any other manufacturer not really allowing for easy access for easy cleaning of these items, well, this has been something to deal with for ever in these things. It is what it is.
Anyway, since my radiator, at 40K miles, (the first time I did the operation) was corroded so bad in a lower corner, it was non-repairable. So, out with the Aluminum-plastic and in with the Copper-brass. The cooling of the Copper-brass is pretty much the same as the original radiator. The changing of the regulators brought the temp down just a tad from 194 to 186 on the average, based on outside temps and level cruising or not.
Anyway, yes, it's real tough to try and to a thorough, efficient, accurate and complete job of cleaning while they're in the coach.
Scott
Scott and Karla SDFD RETIRED2004 Itasca Horizon, 36GD Slate Blue 330 CAT
2011 GMC Sierra 1500 Ext Cab 4x4 Toad
2008 Caliente Red LVL II GL 1800 Goldwing KI60ND
