F53 V10 radiator hose replacement
btcruzer
So, I'm thinking it might be time to replace my coolant hoses. I crawled under there and the hoses look to be great condition but they also look to be the originals. The chassis is an '02. Problem is, they don't look to be anything I could pick up at the local auto parts. I haven't been able to find them on-line, any suggestions?
The Good Times are Coming !
19 REPLIES 19
jerseyjim
I replace my hoses, belts and anti-freeze every 30,000 miles. Fuel filter, too. As far as the hoses go, the top radiator hose is no problem The bottom one...can be. I would suggest you go to Ford to get it.
ArchHoagland
Have you replaced the belts?
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
2000 LEXUS RX300 FWD 22MPG 4020 LBS
US Gear Brakes
btcruzer
Local parts place might be able to come up with a replacement for the upper but that lower piece consists of at least 4 separate hoses and a couple of fittings - all oddly shaped. Heck, Auto Zone couldn't even come up with the correct idler pulleys or serpentine belt.
Yeah, I know, 15 years and all. Time to do it. Once I swipe the card I'll ignore the receipt and life will be good.
dons2346
Take the old hoses into a NAPA store and see what they have to say. Might be more expensive than you think they are worth but you are looking at replacing a 15 year old hose.
btcruzer
Correction, I DID find the hoses online. $80 for the lower assembly and $30 for the upper hose. Is that insane ? or am I? I suffer sticker shock just about daily but this is getting out of hand !
