Flooded Almost!
smacdiesel
Left the Motorhome unattended for a few hours and returned to find the shower tub filled with water! The grey tank was almost empty before I left and I'm curious to why I almost completely flooded my RV. Earlier I took a shower and shut off the water flow from my shower head shutoff valve instead of the faucet valves. I don't usually do this, I just forgot to turn it off from the main valve. There was no water flowing when I exited the shower.
What caused my grey tanks to fill and overflow? There wasn't any water coming form the shower head when I discovered that I left the valves open. I always thought the shower head shut off valve did just that, stopped the flow of water and the filling of the tanks.
I'm stumped.
2015 Winnebago Vista 35B
1983 Jeep CJ 8 Scrambler
16 REPLIES 16
bigred1cav
Please tell me what your setup is? One piece or that valve and an add on?
Thanks
downtheroad wrote:
Good advice from others about SHUTTING OFF water at the source when you leave...Ours is very simple and inexpensive..
lj2654
Always turn spigot off when you leave the site, good insurance, just in case....
2001 Beaver Contessa Naples 40
2012 Cadillac Srx
retired AirForce 1979-1992
lanerd
Sorry, can't offer any possible reasons for your tub and gray tank to fill. Has to be water going into the gray tank from some where. I seriously doubt if a small drip can fill a 40 gal tank plus tub in a few hours.
However, everyone has mentioned about turning the water supply off when you leave. The simple solution is to utilize your fresh water tank and pump. Fill the tank, turn off the water supply, and then use your pump whenever you need fresh water. Very simple.
Depending upon how much water you normally use will determine how often you have to fill your fresh water tank. We only turn on the pump whenever we actually need fresh water....we do not leave it on continuously. It doesn't take long for you to get into the habit of turning the pump on and off whenever you need it. Of course it helps to have multiple pump switches located through out the rv...or it's not that difficult to install them.
Ron
Ron & Sandie
2013 Tiffin Phaeton 42LH Cummins ISL 400hp
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified by U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Allegro
RETIRED!! How sweet it is....
downtheroad
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
BTPO1
This post is kind of like the post yesterday about turning the water pump off. It only takes a few seconds to turn the water off at the post or the pump switch off when leaving for a while. The hard part is remembering to turn it back on when returning.
Have seen water coming from RV's more than once, I really don't want this to happen to me. JMO
Jack
2003 Rexhall Vision 27'
2019 Chevrolet Equinox
States we have been to with this MH
Ivylog
This threaded may motivate me to put a 12V solenoid valve on my city water supply line so I can shut it off when out of the coach. I never use the "Salesman switch" by the door so I could use it to power this solenoid. My pump has several switches to turn it off/on so that is easy... if I remember.
Upgraded with a 08 HR Navigator 45’...
Valkyriebush
smacdiesel wrote:
happy-2 wrote:
I always shut off the water source when i leave the RV.
I think I will begin doing the same, I'm just glad I caught it in time.
I had a coupler on my interior water filter break and started spraying water all under the sink. Lucky I was there and heard the thunk and spraying when it let go. I turn my water off too when leaving! Wish there was a valve inside to turn it back on as I often forget and have to go back out. lol I also leave the grey water valve open when stored at home and the fresh water tank full to prevent what happened to you, just in case.
Command Master Chief (AW) USN, (ret)
2003 Fleetwood Excursion 330 Turbo Cat 39D
2000 Jeep GC
2005 Big Ruckus (Rides Behind Jeep)
2003 VTX 1800
K_Charles
In the last 20 years I have shut off two water lines to campers that had water running out the door. I still don't shut off our water when we leave and I don't know why.
Ductape_Dave
I also turn the water off when I leave the site, except one time when I went to the camp store to get ice cream, I returned to find water coming out of my fresh water fill inlet. Found out the pump check valve went bad and allowed the city water to fill and overflow the fresh water tank. Remember Murphy is never too far behind!
2016 Coachmen Clipper 17BH
2016 Toyota 4Runner SR5
fla-gypsy
If I'm leaving the site for more than a short few minutes I cut the water off. I've seen the damage that can occur in a friends camper.
smacdiesel
ArchHoagland
Had a water line to my toilet break while we were away from our coach a few years ago. Flooded the coach.
Now I always turn the water off at the site when we go away.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
2000 LEXUS RX300 FWD 22MPG 4020 LBS
US Gear Brakes
happy-2
smacdiesel
It must have been a small drip, about 5 hours to fill a 40 gallon grey tank?
