Ford E450 sway bar?,s
suprz
My 2006 E450 has the original sway bars and sway bar links. I cannot afford new hellwig sway bars at this point. I am wondering if anyone has changed the original sway bar links, bushings, etc and how much of a difference it makes.
Proud father of a US Marine
66 REPLIES 66
ron_dittmer
It's too bad Ford doesn't supply RV-outfitted chassis to RV manufactures with all the heavy-duty stuff to begin with. That would make them right from the start.
Every motor home on a Ford chassis, regardless of model year, but especially prior to 2008, should have heavy duty sway (stabilizer) bars, given the chassis is always being driven at max-load conditions.
Our little 24' rig in my signature drove like a drunken sailor when brand new. After our first trip, I had heavy duty front & rear stabilizer bars, heavy duty shocks, rear trac bar, and Safe-T-Plus steering stabilizer installed. It has been a joy to drive the rig ever since.....10 years so far of joy-riding instead of hell-riding.
Community Alumni
Not applicable
j-d wrote:
Might rain, so I got the cardboard out, slid under with a handful of sockets, and here are the E450 sizes, through Chassis Year 2007:
Front and Rear Sway Bar Center Bushing Brackets: Metric 15MM
All parts furnished by Hellwig: SAE 3/4"
There isn't an SAE size that'll "work as 15MM" so you need that specific socket. Standard depth is fine.
You can get away with 19MM for the 3/4" but the socket should be Deep.
I always get Six Point Sockets.
So you'd need a Ratchet, two Sockets, and a Wrench.
Wrench can be an Open End, Combination (box/socket end plus an open end) or an Adjustable. 8" would be nice, but a 6" will open to 3/4".
Again, suggest 1/2" drive for the sockets. I don't like the fastener diameter much bigger than the square drive size of the socket set. The 3/4" tools will be working 1/2" fasteners, and the 15MM is driving screws that are about 7/16".
Footnote: 2008 and newer use two different sizes on the front bar center brackets, the 15MM and something larger. Common next larger'd be 17MM but I don't have a vehicle to check that on.
EDIT: Looked at the OEM rear sway bar end links I removed to install the Hellwig bar. The 3/4" or 19MM socket will remove the frame end. The bar end is 14MM but your 15MM socket'll catch it if you get a six point. Or if your open end wrench is an adjustable.
Thank you for your over and above help. I have tinkered with my motorcycle (oil change, rerouted electric lines so they weren't under the gas tank, changed spark plugs which required some engine mount stabilization, etc). I have a full set of metric and English sockets along with a torque wrench and open ended wrench. My sockets are 6 points so they should grip just fine.
It sounds like a "simple" remove the old sway bar and install the new one in it's place. I will tackle the issue after our Labor Day weekend trip but before our trip to Florida in July. Got to come up with the funding first. Spending way too much right now on the rig.
suprz
I crawled under the front end of mine to look at the front sway bar, and the rubber grommets that are pressed into the I beams are pretty much toast, but the chassis is a 2006, so I wasn't surprised. I guess I will have to spring for the hellwig bar for the front. I see they are around 225.00..... I can't imagine that a Ford dealer would charge less to fix the stock bar grommets... I might also get a new steering damper while I am at it. But there is no way I can do the front shocks... The rear ones, sure, but not the front
RedRollingRoadb
Easy is a relative term. If you are comfortable working with basic hand tools it isn't a problem. Go to sdtrucksprings.com look up your vehicle, scroll down toward the lower part of the page and you will find a .pdf on the install.
chag67 wrote:
stripit wrote:
The factory bars are removed and the new heavier built, thicker bars are installed.
How difficult/easy is the install? Does anyone have a link for step by step instructions or a video?
j-d
j-d
chag67 wrote:
I'm positive I need them. I felt the rig move at every movement of my son in the overhead bunk. I also felt the rig move at every wind gust while parked.
Plus, traveling home, my hands were cramped and sore from having to grip the steering wheel so tight.
I don't mind paying for the Hellwig sway bars but I don't want to pay for installation if I don't have to.
Upgraded sway bars help both on the road, and also on the campsite. You'll still feel people moving around in the parked coach, but no where near as much. After all, the coach is still sitting on springs and tires.
When a Ford Class C sways, that's also an un-commanded steering input, so that's part of why upgrading is so good. Don't rule out needing a front end alignment, one that increases the spec called Caster, but there's a lot that can be done short of that, to improve the drive. Cheapest, around $10, is load the coach as for a trip, people and all, and weigh it on a CAT Scale, then adjust tire pressure to the actual axle weight. Ford chassis is VERY sensitive to front tire pressure.
I helped an RV.net member install a Hellwig rear bar on a Chevy chassis, and the upgrade satisfied him with improved driving and solved his wife's annoyance about the coach bouncing when he walked around in the parked coach.
I think about all you'd need is a 1/2" drive ratchet, a few sockets, and perhaps additionally a 3/4" wrench. An 8" adjustable wrench would probably do.
Part of the reason for 1/2" drive is the amount of torque specified for some of the fasteners.
The Hellwig parts themselves are SAE wrench/socket sizes. The fasteners you have to take out and re-install to hold the sway bar brackets to the front frame and rear axle are Metric. Harbor Freight tools are just fine for a project like sway bars, and for the home tinkerer. Their basic 1/2" socket set is about $25. Stores like Lowe's and Home Depot have individual sockets you can add for a couple Metric fasteners. The auto parts chain stores, loan tools. They're usually specialized tools, but they might also loan socket sets. Basically you buy the tool. Then use it and return it for a refund.
Would you like me to go out to our E450 and get you the wrench sizes?
I think Ron.Dittmer, posted above, can link you to an RV.net thread, where he and his brother added a rear sway bar to an E350. That would be actually a little more difficult than swapping an OEM E450 bar for a Hellwig.
Wish you were closer, I'd offer to help. I've been to Maxwell, but no business out that way for the foreseeable future.
Community Alumni
Not applicable
I'm positive I need them. I felt the rig move at every movement of my son in the overhead bunk (I was in the back bed). I also felt the rig move at every wind gust while parked. If felt like my son was jumping up and down in the RV.
Plus, traveling home, my hands were cramped and sore from having to grip the steering wheel so tight. It was a very windy drive home and I was having to fight the whole time trying to stay in my lane.
I don't mind paying for the Hellwig sway bars but I don't want to pay for installation if I don't have to. I don't have a vast assortment of tools. Just your normal tool kit you get from any home improvement store. Something similar to this - Average tool kit from Home Depot
j-d
Er, Ah, Yes... Look up to Page One in this Thread. I posted links to the Part Numbers, Illustrations, and Prices of Front and Rear Hellwig Bars for E450 up through 2007.
Within each of those links, when you open the page for each bar, then you can click on the Installation Instructions and see those too.
ron_dittmer
CLICK HERE to read a post I wrote for Phoenix Cruiser owners to determine if their suspension could benefit from the things discussed here. It applies to all motor homes.
BTW: I agree with everything j-d is sharing.
j-d
Hellwig (Roadmaster, too, at twice the price!) Sway Bars replace the OEM bars.
OEM front bar is 1" diameter and Hellwig is 1-3/8"
OEM rear is 1-1/8" and Hellwig 1-1/2"
Roadmaster is same dimensions, same steel, just pricier.
Community Alumni
Not applicable
stripit
chag67 wrote:
I noticed a lot of sway this past weekend driving my 2007 E450. Does the hellwig replace what is on the rig currently or is it in addition too? Please excuse my ignorance on the subject since I am not mechanically inclined at all.
Stacey Frank
2016 Tiffin Allegro Bus 40AP
2019 Tesla Model X
2015 Cadillac SRX we Tow
1991 Avanti Convertible
Community Alumni
Not applicable
j-d
sullivanclan wrote:
What would the hellwig rear sway bar cost?
In my link above, rear is $263, free shipping, maybe sales tax. Amazon has them, price seemed about the same, and then there's SDTruckSprings.com
Price is going to bounce around a little since somebody's usually running some form of promotion.
I ordered mine from SD, forget if it was free shipping but there was a discount. They actually shipped right from Hellwig.
Rear bar's heavier than the front, but the install is easier and faster. On the front, for 2007 and earlier, you "build" the end link brackets that clamp to the axles. Just plates and U-Bolts, but it takes a little effort to position and tighten them. The rear uses existing attachment points. So does the front for 2008 and newer.
sullivanclan
What would the hellwig rear sway bar cost? I have a 2003 Ford 450 Jayco, sounds like just what I need. I'm thinking my son could do it since he has under car mechanical experience.
2003 Ford 450 Jayco Greyhawk 25D
1986 Jeep Renegade
2011 Jeep Unlimited Rubicon JK
