Ford V10
haste_maker
This question is for those that have a Ford V10 in a class A. I have a 2007 Allergo 32BA with the Ford V10 that only has 36,000 miles on it & I took it to mountains of Western NC this week, and it seemed weak on pulling power, I tried to keep the RMP's below 4000, and at time's I was down to 40 mph, I was pulling a 2003 Honda Element...it this normal?
Retried Teamster
2007 Allergo
25 REPLIES 25
wynnd
Maybe too basic, but when was the last fuel filter change?
2007 Fleetwood Terra 34N X2 w/bunks
wildmanbaker
This is typical for 415 CIs pulling 20K pounds +. I would not go above 4,500 RPM. Some say the V10 is a high revving engine, but the computer limits the rpm to about 5,200. Try anticipating rises in elevation, and applying power in advance. If speed sags, us a lower gear. If you get to the top of the grade, you have it half made.
Wildmanbaker
Horsedoc
We have a 3911 Newmar Canyon Star and tow a Wrangler. This is the first gasser we have ever owned. We got out of 425 Cummins coach into this one and was disappointed in performance. But it is handicap accessible with a ramp lift. The more we travel in it, the better we like it. It certainly does not climb like the pusher, but it does get to the top. The V-10 does torque at a higher RPM but I don't like the noise that comes with it and (I know it is a mental thing) the tach at 4K.
Other than that, we are well satisfied with the engine performance and the coach itself.
horsedoc
2008 Damon Essence
2013 Jeep Sahara Unlimited
Blue Ox tow
harley-dave
You might look into a 5 Star Tuner for the V10. We've had one in our 32' Class C that we tow with. Made a huge difference in climbing and cruising. We tow a Chevy tracker with ours which probably is similar in weight. We have better shifting, climbing and even 1 MPG better mileage.
Dave
2005 Winnebago-Itasca Sundancer 31C
2010 Harley-Davidson Soft tail Deluxe
2014 Harley-Davidson Street Glide Special
1999 Chevrolet Tracker 4X4
SKP # 121272
MountainAir05
howdy35 wrote:
Back in the day I had a 1999 35 ft Bounder that I pulled a 2000 Honda Accord with. Tripped all over the Rockies and never doubted the ability of the coach to get to the top. Yes the V10 likes the RPM going up and she screams like a scalded dog, but she always hauled it to the top. I was never in a hurry and flashers on if down to 40 and enjoy the scenery. That engine is rock solid and can stand the RPM if you can stand the noise. Just a thought. Safe journey. Arnold
We also had a 99 and 37.5 foot and towed a Saturn. We live in the Rockies and the same thing. Never had an issue going up or down "gears"
howdy35
1999 National Tradewinds 7370
2014 Honda CR-V--Toad
Fulltime
vjstangelo
40 MPH with a dinghy is typical of what we just did in the mountainous section of I-70 in CO. I was trying to keep the RPM at 4200 but based on posts maybe 4700 would have been better. Worst grade was this trip I-70 from Dillon to Eisenhower Tunnel, 12 miles of 6%. Don’t like straining the tranny like that as it was making some strange whining sounds the last mile or so (5 speed Torqshift). May unhitch the dinghy if we ever do that grade again.
2012 Winnebago Vista 32K
2011 Honda CRV Toad
KD4UPL
That engine makes its peak torque at 3,250 RPM. It makes peak HP at 4,750. To climb a hill in a hurry you need more HP. So, by staying below 4,000 RPM you are giving up HP that the engine could be making if it was spinning faster at 4,750. However, many people say the "best" RPM to pull a grade is at peak torque. At that RPM the engine is most efficient at hill climbing but not necessarily the fastest. So, take your pick, you can have speed with RPM or you can have efficiency and possibly cooler temps at peak torque but you can't have both.
azdryheat
You gotta go above 4 grand. It likes it there.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
MountainAir05
That is where I try to keep mine at on rpm and 40 mph going up and in a lower gear.
George_Beggs
You have to keep the RPM up. 5000 RPM is not a problem.
George & Linda
2007 Bounder 35E
Ford V10
