furnace blower
BingMyDog
The LP furnace blower in my 2002 Winnebago Adventurer will not start.
If the blower does not start the furnace will not lite. I think it
is a voltage problem.
5 REPLIES 5
ksg5000
Might be an issue with your thermostat - if the prior owner upgraded to a digital thermostat then it might be as simple as replacing the battery inside the thermostat.
Edit: You should also note that your furnace fan won't operate if your coach batteries are dead/too low.
Kevin
Old-Biscuit
MAIN DC FUSE>.........good or blown. Test it not just look at it
Then if Atwood brand check on/off circuit breaker in furnace compartment on frame in front of motor. Tripped/reset it and see if fan runs
IF Suburban brand check for 12V DC to time delay relay and on Red wire to motor.......no 12V DC then replace time delay relay
enblethen
Make and model of furnace?
Look for a circuit breaker on top of fan housing. Should have small reset button either red or white.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
crasster
First place to start is the breakers and fuses. Next go with a meter and FIND OUT if it is indeed a power problem.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
Sam_Spade
A complete LACK of voltage, maybe.
A meter is required and tests need to be made.
It is also possible that the fan motor itself has failed.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
