Gas Coaches and air compressors
Rheevs
Who carries a compressor in their gas coach and what kind.
I need 90psi for my tires.
Life Is A Journey Not A Destination
Good Luck !
Vicki and Ed
2013 Winnebago Adventurer WFJ35P
The Saratoga
31 REPLIES 31
AstroRig57
I had two Husky air compressors from Home Depot fail. One failed within days of purchase on our first trip with it. The second , the warranty replacement, failed a few months later (but only the second time I had used it).
I quit messing around with the cheap consumer brand and opted for a Senco which has been faithfully airing up my tires and air bags for seven years now. As near as I can tell, this is the equivalent model.
Senco 1 Gal. 1/2 HP Portable Electric Air Compressor
2005 Winnebago Sightseer WFD30B "rigged for night" with red LED lighting for night adapted vision.
Do you remember when the sky was dark, and the stars were bright?
The International Dark-Sky Association
American by birth...Scottish by the Grace Of God.
cjalphonso
jkcruzer1 wrote:
10forty2 wrote:
This is the one I carry. It's got a 3-gallon tank on it so it can air up the big loads a little faster. I Caught it on sale at Lowe's for around $120.00. It, along with 50' of air hose, fits in the front bin under the driver's side door very nicely.
X2
It's reasonably quiet, too. On sale about a month ago for $99.
I just purchased this one. I believe it is better than the dewalt shown because it has a 3 gallon tank, 150psi and 1.5hp. This thing brings the 3 gallons up to 150psi in less than 1 minute and filled my MH tires to 90psi very quickly with plenty of pressure to spare.
Hope this helps.
mustang652
dcbrewer wrote:
I carry a Porter Cable Pancake, will do 150 lb.
Same here. The one in the coach is seven years old and have been impressed enough that when I had to leave my larger garage compressor when we moved to Texas, I bought another Porter Cable Pancake to but in garage of new house.
Stan, Shirley & 2 Schnauzers
RV: 2014 Itasca Sunstar 35F
USAF Retired, Life Member: VSPA, VVA, DVA,VFW
time_to_go_now
the silverback wrote:
Everyone keeps talking about the size of the tank. You do not need a tank!!! It is a waste of space, weight, and money. I have a single cylinder 125 psig 2 cfm compressor. no tank, about the same size as a loaf of bread. works great.
You don't need a motorhome either. It is not a need. It is a want. And try and run a set of train horns without a tank!
Good luck.
Jim and Deanna
2008 Tiffin Allegro 35QBA FRED
2007 Carson Trailer 22' Titan TH
Trailer Toad
Me, Wife, Boy/22, Boy/19, Girl/17
1985 Toyota 4Runner
TWO quads, THREE kids, TWO motorcycles, ONE wife, TWO dogs, ONE cat, TWO Polaris RZR's
bigbaddad
I have always used a 3 gal. tank 110v unit. Had a 12v unit but it took forever to raise a tire from 75 psi to 100 psi. because the cfm at 90 psi was pathetic. Be sure you get something that will deliver at least 3 cfm at your target pressure. Also, check to see that you can easily adjust the cut-in and cut-out pressures before you get one. You need to keep the cut-in above the target pressure for your tire.
the_silverback
the silverback
2015 crossroads Rushmore 5th wheel
creeper
holstein13 wrote:
What's a "driver's side door"? ๐Ÿ˜‰
It's a door next to the driver. ๐Ÿ™‚
holstein13
2015 Newmar King Aire 4599
2012 Ford F150 Supercrew Cab
time_to_go_now
That is a lot cheaper than a good 12v compressor! I probably have $1,000 invested in a good 12v compressor, an 8 gallon stainless steel tank, electrical wiring, and plumbing quick disconnects to both sides of the rig.
But, I also run air horns and have future plans for air bags.
Jim and Deanna
Trailer Toad
1985 Toyota 4Runner
jkcruzer1
X2
2011 Damon Challenger 371
dcbrewer
creeper
I need 100-110psi and use the Viair. If I had to do over I'd install a set of Klein air horns and inflator combo.
FormerBoater
holstein13 wrote:
Here's the one I used to carry in my gas coach:
It was fantastic. Filled the tires quickly and was very light, easy to carry and economical.
Works great in a diesel as well!
Light, fills my 275/70/22.5's to 110 on the fronts and 95 on the rears.
With 1 25 foot extension cord I can reach all six without plugging and unplugging the power.
Very small footprint in the storage bay.
Dave
1998 American Eagle 40EVS
two_travelers
We carry a 1 gal pancake compressor from Harbor Freight. Ok to top off. Valve stem leaked one time and had to put in 90lbs - took for ever but it got the job done.
