โApr-20-2015 06:49 PM
โApr-22-2015 03:04 PM
Executive wrote:
On another note......when the accelerator gets stuck like that, sometimes it's best to simply turn the key OFF rather than fight the brakes and the engine.
โApr-22-2015 06:29 AM
โApr-21-2015 10:50 AM
catsgalore wrote:
We have been driving this motor home since 2003 and never imagined anything like this happening. This particular Fleetwood model has the motor sitting inside between the driver and passenger seats. I don't know to much about the mechanics of this RV but just looking at the gas pedal I can see it is way to close to the fiberglass firewall next to it. The mechanic that came the next day used a crow bar to clear a space in between and he also took a corner of the pedal off so this never happens again. It was a very frightening situation but I thank God there were no other cars on the road at all that day and also that my husband did not panic and calmly did what he could to get the vehicle stopped. We have a braking system on the tow vehicle and I think that helped as well.
โApr-21-2015 09:58 AM
โApr-21-2015 09:22 AM
โApr-21-2015 09:18 AM
โApr-21-2015 09:00 AM
Wrong Lane wrote:
I have often wondered why the driver in a stuck accelerator situation doesn't just throw it in neutral and brake to a controlled stop. If the engine blows up then so be it. That would be preferable to injuries or death!
There was one well publicized stuck accelerator case, that resulted in fatalities, where the driver of a medium sized car was on the phone with a 911 operator and apparently no one thought about putting the car in neutral.
I am glad to hear the OP is safe and sound.
โApr-21-2015 08:55 AM
โApr-21-2015 08:32 AM
โApr-21-2015 06:28 AM
Gjac wrote:
This was a dangerous situation which I never thought about before your post. I worried about losing my brakes on a downhill and what I would do. I have turned the key off on my tow car and it was hard to steer and the brakes at first worked but after several pumps they became very hard to stop. I can't imagine trying to steer a MH with the eng off down a windy road. I wonder if the power steering pump would work somewhat if the eng was still in gear rather than neutral? Glad you OK.
โApr-21-2015 06:24 AM
โApr-21-2015 05:59 AM
โApr-21-2015 05:42 AM
โApr-21-2015 04:35 AM
Executive wrote:
Have you determined WHY the pedal stuck? Did it get jammed or wedged somehow? I'm trying to picture why and how the pedal might get stuck.
On another note......when the accelerator gets stuck like that, sometimes it's best to simply turn the key OFF rather than fight the brakes and the engine. The power brakes won't work as well but they will work. Better than picking up too much speed and if the brakes finally heat up and fail, you're screwed....glad to hear you came out of this incident ok...must be terrifying.....Dennis
