Gel Coat on a New Motorhome. Good Thing or Waste of Money?
Coachy
Getting ready to make the jump to a newer and bigger coach, a Tiffin Allegro Open Road 31SA with full paint like most coaches today.
Trying to decide if the additional cost of the gel coat is a necessary expense to protect the paint or another way for the dealer to just make additional profit? Or are there alternatives?
People on this forum are so knowledgeable I heavily rely on your posts and opinions when making these type of decisions. Thank you for your time and sharing of your experience.
8 REPLIES 8
deandec
IMHO, once the Gel Coat is fully painted and protected by several layers of Clear Coat, there is nothing more needed.
The Clear Coat provides the UV protection we used to seek by waxing our paint. So wax is just extra effort and money on painted fiberglass. Wax is great on colored but non-painted Gel Coat (search for Red Max Pro discussions).
Polish buffing will bring up the shine a bit if the clear coat is dull, but polishing will remove some Clear Coat as polish is just a gentle abrasive. Too much polishing and you will need to replace the Clear Coat, which also will require new base coat. JMHO.
Dean
95 CC Magna, Jeep GC
Gjac
Although gel coat can be applied after the parts are made and assembled, I just did it on a 14 year old FG boat. It can be sprayed, rolled or painted on. Having said that I doubt that is what Tiffen is marketing. You don't want "extra" gel coat on because the thicker it is applied the more it is prone to surface cracking especially under darker painted exteriors that newer MH's have.
mtrumpet
Coachy,
Might you possibly be getting "Gel Coat" confused with "Clear Coat"? As you say that the coach already has full body paint, it is already clear coated as well.
Mark & Cherie
2002 Newmar Dutch Star DP 3872, Cummins 350 ISC, Spartan Chassis
smlranger
Sounds like dealer hooey! A coach with base coat/clear coat has urethane clear on it. IMO, paying dealers (car or RV) to put additional paint protection stuff, regardless of what they call it, is simply wasting your money and padded their pockets.
Just put some wax or polish on it once or twice a year and it will do fine.
2019 Grand Design Solitude 384GK 5th wheel. Glen Allen, VA
Francesca_Knowl
VintageRacer wrote:
Gel coat is not something that a dealer could apply.
Spot on!
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
VintageRacer
Gel coat is the outer layer of the fiberglass layup that is applied to the mold during the fiberglass part production process. It can be polished to a reasonable gloss and can last for a while unpainted, but most people find that it will oxidize and dull after a period. You can then either repolish and apply some kind of protective coat, or paint. Gel coat is not something that a dealer could apply. Now, some kind of gel coat protection they could apply. It's basically just polish and wax coat, I wouldn't bother with that if it costs more than a normal buff and polish job.
Brian
2005 F250 Supercab, Powerstroke, 5 speed automatic, 3.73 gears.
20 ft race car hauler, Lola T440 Formula Ford, NTM MK4 Sports Racer
1980 MCI MC-5C highway coach conversion
2004 Travelhawk 8' Truck Camper
Bob___Ann
coachy
If you are buying a Tiffin I would not spend any additional money at the dealership for gel coat. Tiffin puts up to five coats of clear coat to protect the paint. You can call the Tiffin plant in Red Bay and I believe that they will tell you not to do it. If you would like to ask questions about the Tiffin you need to go to www.tiffinrvnetwork.com. There you can ask your questions to a large base of Tiffin owners. I think that you will find it to be helpful. Good luck with your purchase
Bob and Ann
Schnauzer - Della (Rainbow B 3/31/17)
Chihuahua - Lola (Rainbow B 12/26/18)
Autumn-Red Poodle
2019 Tiffin 40 IP Bus
Powerglide Chassis
Cummins 450
Onan 10,000 Watt
Four Slide/ 1.5 Bath
2021 Jeep Unlimited Sahara Toad
Demco Dominator & Airforce One
ScottG
There are different grades of Gel-coat. If they don't use the best grades then it will dull and deteriorate in the sun. Take a look at any cheaper trailer that's a few years old to see what I mean. You can probably find good examples on the dealers lot.
New paints are so good that I would just rather have them than GC.
