sandblasting
rickvikki
Goodmorning everyone.
We have a 40ft phaeton motorhome and are presently in the rio grande valley area of texas.
We would like to have our motorhome underbelly sandblasted and coated. Does anyone know of a company in south texas that does this?
Thanks
Rick and vikki
Rick and Vikki Landry
Ottawa, Canada
Tiffen Phaeton 2006 (40 ft.)
13 REPLIES 13
Argosy24
I sandblasted and painted mine several years ago. You have to use some common sense about how you do it but I've had no problem because of it. I primed then painted it white, it's much easier to see to do maintenance.
BrianinMichigan
Hers is a you tube video on " dustless blasting "
Dustless blasting
1990 GEORGIE BOY 28' 454 4BBL, TURBO 400 TRANS,
CAMPING: WHERE YOU SPEND A SMALL FORTUNE TO LIVE LIKE A HOMELESS PERSON.
wildmanbaker
Thanks for the info, I wonder what the "greenes" think of this.
Wildmanbaker
mtrumpet
Yes, oiling the underside of vehicles is still a common proceedure. I have my have my Dodge Ram 1500 done once a year. Costs about $100. per application. Although, I'm sure that it would be considerably more for a motor home.
Krown vehicle undercoating
It is a bit messy afterward as it drips for as much as a few days. Not a problem on grass or a black top driveway, but can stain a concrete driveway. Keep in mind that the coating ("oil") is clear. Not dark as typically thought of when thinking "oil". Seems to work well. I guess I'll find out in a few years.
The Krown Company is Canadian based, but they have many locations in the states that do the applications.
Mark & Cherie
2002 Newmar Dutch Star DP 3872, Cummins 350 ISC, Spartan Chassis
BrianinMichigan
I forgot about CO2 blasting. I have a friend that has helped a buddy of his do CO2 blasting on commercial buildings it'll knock the heck out of what is being blasted but leaves nothing but the debris that is being hit.
bsinmich
It was cheaper than undercoating but had to be done every year. It worked best if you left the car outside because it did drip for a while.
1999 Damon Challenger 310 Ford
wildmanbaker
bsinmich: I would like to know more about "oil the bottoms of vehicles". Seems like it would be quite a mess, and probably expensive.
Wildmanbaker
bsinmich
Do they still oil the bottoms of vehicles in Canada? That used to get done every year by a couple of my Canadian relatives and might do what you are trying to do.
Bill___Kate
Ask about soda blasting. It like sandblasting, but uses sodium bicarbonate (baking soda) - usually in water - rather than sand, and is commonly used on industrial equipment that might become contaminated if sandblasted. In our area they often use it on fiberglass boats to remove old bottom paint, and the higher end body shops have the equipment for use on trucks and autos. It is still important that you have someone do it that knows what they are doing, and it will not be cheap.
Bill & Kate - Stone Harbor, NJ
w/ Bailey (standard poodle) and Zeke (partipoodle)- both rescues
2018 Ford F-250 Super Duty Crew Cab w/ 6.2L gasser
2014 Forest River Wildcat 272RLX fifth wheel
hammer21661
Brian in Michigan wrote:
Having done some sandblasting I can say I would not do it. There is way to many areas that sand can get in to where it doesn't belong. How bad can the underbelly be?
My thoughts exactly.
2018 Ram 3500 SRW crew cab long bed 4x4 diesel Lariamie 1-2018
2013 fuzion 322.8/25/2012
2000 Yellow Lab mix Dog, Earl,The One who gave me Unconditional Love picked up 9-12 or 13, 2001 till 2-7-2014 may he r.i.p.
PastorCharlie
I would recommend a degreasing solvent be sprayed on and then pressure wash before undercoating.
BrianinMichigan
SooperDaddy
I Googled "south texas vehicle undercoating" and found a number of undercoating services, some specialize in trucks and RV's.
My posts shouldn't be taken for factual data, and are purely fictional, for entertainment purposes, should not be constituted as related to scientific, technical, engineering, legal, religious, spiritual, or practical advice. After all it's FREE! Amen. :W
