Generator Exhaust Stack
TennTechMan
Has anyone ever made a generator exhaust stack for their RV? What I'm imagining is an exhaust extension that would reach up just past the roof of the RV. I'm hoping it achieves a couple of things. Most important, I'm hoping to get the exhaust fumes up above everyone hanging out around the RV. Second, I think it'll be a little quieter since exhaust is directional. The sound isn't particularly loud now, so that's much less of a goal.
This will likely be something that can easily be attached and removed, so that it isn't in place while traveling.
Thoughts?
-Aaron
1996 Winnebago Brave 33' - Ford F53 Chassis
Banks Power Pack and Trans Commander
14 REPLIES 14
bobkatmsu
wny_pat wrote:
Like Vic46 said, do a search for build one yourself DIYs. There are several homebrew designs out there that use everything from metal gutter pipe to plastic pvc. You just have to make sure you have a opening on the bottom side to draw fresh air in.
Here's one found by google: http://www.thumpertalk.com/topic/645714-my-homemade-genturi-generator-exhaust/
We travel to many University of Florida football games and RV's are parked nearly on top of each other. The vent is a necessary. The problem most diy models have a hard time drawing the air into the unit. If this is something you have fun with there are some good directions on the forum. If you just want it to work the Gen-turi is a good value and easy to use.
2010 Newmar Dutch Star DP
2014 Jeep Wrangler Sahara
Mainehawk
We actually purchased and installed one of the Genturi towers. We did have to make a modification to extend the connectors so that we could accomidate the basement door. With the door closed, the generator would over-heat. This way we can maximize the air flow and still kick the fumes out over the wagon.
TennTechMan
It's good to see that it seems I had a pretty good idea. Or at least a common idea. I've never seen one of these things before.
Thanks for all the great comments. I'll post back with whatever I end up doing.
-Aaron
jmanatee
Heres the one I made http://www.outerland.com/rv/P_n_genturi.cfm?whatarea=PNR
Jon
RV Web Site | 50 Night Cross Country Trip
Our Solar Install | Roof Replacement Project
Twenty years from now you'll be more disappointed by the things you
didn't do than by things you did. Explore, Dream, Discover. Mark Twain
2010 Keystone Everest 348R
DSDP_Don
I fabricate pretty much anything my coach needs like shelves, metal brackets etc, but there are just some things that it's better to buy the one made commercially. The Genturi is one of those.
Just so you know, the Genturi won't be the cure all to your noise. It will reduce it some, but gas generators are loud. Add the Genturi and try taking an old piece of dense shag carpet, (about 36' x 36') and throw it on the ground under your generator. A lot of the noise from the gas generators is bouncing off of the ground.
Don & Mary
2019 Newmar Dutch Star 4018 - All Electric
2019 Ford Raptor Crew Cab
jcthorne
The Genturi is often on sale at both Camping World and Amazon for around $90. It includes the storage/carry bag for the pipe, adaptors and all mounting and support parts.
2008 Damon 3575 (38ft, forward kitchen)on Ford 22k chassis
Ivylog
Here's three pictures of one I made out of alum gutter down spout for $15. If no one real close, I sometimes only use a 90 degree conduit sweep as once you get the hot air going up, it keeps going.
*Got a chuckle out of reading some of the post about making your own when you put it on a 6 figure RV. For those that say go buy one for $109... it's really costing you $#150 after all taxes (income tax 35%).
Upgraded with a 08 HR Navigator 45โ€™...
wa8yxm
I use the Camco Gen-Turi.. advantages are it is easy to assemble and attach, take off and bag, it has only once gotten too hot to touch, (That was from the heat of the sun, NOT the generator) I've run with it for 24 hours straight and still able to hold on to the black pipe for over a minute comfortably (just do not touch metal parts) And it is very light weight.
I have seen home made versions.. Some get hotter, and all of 'em are heavier.
Do not park next to me without one if your generator exhausts towards me please. (either home made or store bought, I don't care.. Just make sure you have one)
wny_pat1
โ€œAll journeys have secret destinations of which the traveler is unaware.โ€
vic46
Check the DIY.
[COLOR=]Never argue with an idiot. You will be dragged down to their level and then beaten with experience.
Dutch_12078
Note that the "venturi" design of the Gen-turi does not create a back pressure issue with your generator, and the riser pipe remains relatively cool. They work well for redirecting the fumes and the exhaust noise away from ground level.
The Gen-turi is also available from Amazon.com for $109.
Gen-turi Generator Exhaust
Dutch
2001 GBM Landau 34' Class A
daveshan
Search for Gen-turi and genturi (folks spell it both ways) in addition to results on the manufactured ones you'll find lots of ways people have made their own.
Our coach came with one, if it hadn't I'd have bought one for sure. They are easy to cobble together but for the price all the adapters and attachments are well worth the price of the "out of the box" one IMO.
'99 Alpine 36SDS/8.3 ISC 330 Cummins
Or
'05 Lance 845
'06 Super duty SC/SB 6.0
Upgrades include: StabilLoads, Air Bags & Timbrens,Swaybars
Usually towing an '01 Wrangler, lifted/locked on 35"s or a mildly built '98 Cherokee on 33"s (only one locker)
M_GO_BLUE1
Thoughts? Yes its called a GENTURI and can be purchased at Camping World, PPL Motorhomes and alot of other online RV parts websites...
GENTURI
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
Yankee_Clipper
Keep in mind that extending the exhaust pipe 12-14 feet will increase the back-pressure on the generator engine. This could have an effect on its performance.
Yankee Clipper
2014 Winnebago Sightseer 33C on Ford F53 6.8l V10
2014 Honda CRV 4 down toad/Roadmaster Falcon2 with EvenBrake
TireMinder TPMS,Tiger, the Little Big Man minidachshund,
Rosey the minidachshund resident Princess-in-Chief
