Apr-06-2019 07:10 AM
Apr-16-2019 03:08 AM
Apr-07-2019 07:06 PM
Apr-07-2019 10:22 AM
Apr-07-2019 05:46 AM
Gjac wrote:zigzagrv wrote:Where did you find the break? I tried tracing the wires from the circuit board up front to the switch but lost it very quickly in a harness of wires.
Had the same problem. Was a broken wire coming out of the harness at the generator. I would guess that is the problem with yours since neither remote switches work.
Ron
Apr-06-2019 04:31 PM
Apr-06-2019 03:52 PM
Apr-06-2019 12:01 PM
Apr-06-2019 10:30 AM
Ron
Apr-06-2019 09:53 AM
Gjac wrote:
I have a Kohler 5ckm21 genset it will start from the switch on the genset itself but not from the switch above the stove or the dash board. When the genset is running the light come on the switch on the dash and both switches will shut off the generator, but neither switch will start the generator. Any ideas of what is happening here?
Apr-06-2019 08:54 AM
Apr-06-2019 08:41 AM
ksg5000 wrote:That is the first think I did, but it did not help. The thing that is confusing is both switches work to shut the genset down but only the one on the genset itself works to start and stop.
If it's like my Onan you might check/clean the connections to the board on the generator.
Apr-06-2019 07:49 AM
Apr-06-2019 07:45 AM
MountainAir05 wrote:It will not turn over.
Do you mean it will not turn over from the other two switches or it will not run.
Apr-06-2019 07:24 AM
