grey water draining very slowly
late_bloomer
Hey folks
Seems that when I drain my grey water, it comes out gushing at first, then slows to a trickle. The sensor shows full all the time. I'm guessing there's some kind of buildup in the system somewhere. What kinds of methods have you used to fix this?
I got here as quick as I could.
7 REPLIES 7
late_bloomer
It has happened every time. We're still pretty new to this coach, but that's about to change as DW is retiring Friday! I haven't tried tilting it yet, and one youtube video suggested pouring some liquid automatic dishwasher detergent in the drain to break up grease and crud. I'm going to try that, since we get an odor from the grey drain when it gets full. (odor comes from the shower drain) Thank y'all for the help
schlep1967
My suggestion is to open the drain and leave it open until nothing is trickling out anymore. Close the drain. Go inside and run hot water in the sink until there is no more hot water in the water heater. You can supplement this with a good size pot of boiling or near boiling water from the stove. Wait 5-10 minutes and then open the drain again. Doing this a few times should melt off the grease that has built up in the tank and improve your flow. From here on make sure you wipe everything off with paper towels before putting it in the sink for washing.
2021 Chevy Silverado LTZ 3500 Diesel
2022 Montana Legacy 3931FB
Pull-Rite Super Glide 4500
dave17352
If if shows completely full all the time sounds fishy your sensor is probably screwed up like most of them are. Why don't you dump the grey and see how many 5 gallon buckets of water you can pour down the shower drain. Then you will know if it is just a sensor issue.
NOW 2017 Leprechaun 260ds
2005 Forrest River Cardinal 29rkle FW
1998 Lance 980 11'3" TC
2017 CHEVY 3500 SRW 6.0
B@W turnover ball @ companion Hitch
Honda eu3000 generator mounted on cargo rack
Crestliner 1850 Fish Ski boat mostly fishing now!
paintedtugboat
When they install the tanks, they use hole saws to create the inlet openings at the top and the outlet openings at the side /bottom. They rarely remove the disk created by the hole saw in the gray tank (they usually can fish out the black tank disk because it is a 4 inch opening). These disks can cause the water to run slow when they get near the drain opening. You may also have a vacuum build up if the vent is clogged. Here is a trick: When the gray tank stats running slow, open the black tank valve; this will vent the gray tank since the black tank was drained first and is empty.
Bob and Joan Alexander
2010 Tiffin Phaeton 36QSH (Phaeth)
2013 Jeep Wrangler Sport (Hope)
Lobo & Juniper
Full-timers since 2014
http://www.phaethtofulltime.com/
fitznj
First Comment is that the sensors are not trust worthy - mine are very inaccurate and have been since new.
Try closing the grey port and stick a use a hose pipe to fill the tank as much as possible. You'll know you're nearly full when the drain in the shower stops draining. Then open the grey tank valve and full drain the tank - try to tilt the camper so gravity is helping you out.
Otherwise, you can use a "plumbers snake" to come in through the valve (careful here - don't force anything);
Gerry
Gerry
rgatijnet1
I sounds like you have something that is loose in your gray water tank that shifts during the draining process and plugs the hole.
I would not trust the gauges but you have to determine whether your gray tank is emptying completely. If you have a piece of debris in the tank, the only way to get it out is to try to fish it out with some type of hook to snag it.
DKeppner
Sounds more like a vacuum issue - no air getting back to the tank to equalize - especially true if the gush happens every time. Rock the RV slightly or simply run some water into that grey tank (kitchen or shower) and see if the flow kicks right up again. If it does, its simply vacuum, if not, then look for buildup or vent plugs etc.
Its not the Destination or the Journey.
Its the Excursion
