โDec-05-2014 07:08 PM
โDec-07-2014 02:16 AM
โDec-06-2014 03:12 PM
โDec-06-2014 02:07 PM
โDec-06-2014 09:41 AM
Many 50A RV panels aren't set up to permit 240V branch circuits. They have a dual breaker for the main, and then two bus bars for the two legs go off in opposite directions.
โDec-06-2014 09:29 AM
โDec-06-2014 09:27 AM
โDec-06-2014 09:22 AM
Golden_HVAC wrote:
Many RV's have a air duct that runs under a couch towards the drivers compartment, and that is about 4" diameter, and will carry about 100 cubic feet per minute. I guess that you need one more vent going forward?
You should be able to buy a 4" wye at a hardware store, and connect into the existing air ducts. Then run something like flexible dryer hose to the location that you need more heat.
โDec-06-2014 09:18 AM
Cheyenps wrote:
Assuming your 'home has the 50A (240/120v) cord and plug setup, I'd look at installing one or two "kickspace heaters" that operate on 240 volts and hard wire them to the circuit breaker panel.
Like this:
https://www.acwholesalers.com/Dimplex/CKHA20D31W-1800-Watt-Kick-Space-Heater/39363.ac?gclid=CNbDqMLuscICFYeBfgodHnQAiQ
They are made to install under kitchen/bathroom cabinets so all you see after installation is the grille.
Advantages are no freestanding unit to trip over, hard wiring eliminates worry about the adequacy of existing circuits/recepts, quieter than a lot of portables and a nice clean installation. 240 volt operation allows for higher wattage outputs as well.
โDec-06-2014 08:47 AM
โDec-06-2014 07:56 AM
โDec-06-2014 04:16 AM
โDec-06-2014 03:14 AM
โDec-05-2014 11:56 PM
โDec-05-2014 07:49 PM
Porsche or Country Coach!
