HELP!..Motorhome cranks but will not start
bullydogs1
3 weeks ago...all fine...motorhome started and ran fine..full tank of diesel....go to start it and it cranks but will not start...generator is fine..and runs fine...tried to turn key and let fuel pump run..several times..still cranks but will not start...not even close...was about to head out on Thursday and now?????...is there a fuse for the Cummins fuel pump..?... (ISL 400)..
Stuart and Stella Denning
2016 Entegra Aspire 42RBQ
The 3 Bulldogs (Daisy, Sylvie and Stashie)
2018 Equinox Diesel (TOAD)
19 REPLIES 19
Tinstar
I was guessing it lost its prime but I don't know what the procedure is on the newer electronic engines . I have a lift pump on mine or I can crack open a banjo valve at the cylinder.
:CNever pass up a chance to go somewhere:C
Ivylog
Just goes to prove we need to use them more often... Glad it's running
Upgraded with a 08 HR Navigator 45’...
DSDP_Don
I think your problem is even worse......your wife got it to start!:o
Don & Mary
2019 Newmar Dutch Star 4018 - All Electric
2019 Ford Raptor Crew Cab
bullydogs1
UPDATE>>>MY WEEKEND IS SAVED!!!!!!!...'
went to Raleigh today...last night must have cycled ignition 8 times..and let it be....this afternoon wife tried it and it kicked..she tried again and VOILA....runs perfect...has started everytime since...had two people coming over tomorrow to look and was ready to pull the tow plug....somehow air must have purged in and it lost prime......but I AM BACK IN BUSINESS!!!..thank you to all who responded....a bit perturbed at CoachNet..but I could have dealt with it...somehow the people who man the phones there are not as knowledgable as they used to be.....
bullydogs1
It's all electronics....no supposedly, no shut off arm....they are suspecting a cam sensor on it, and if so, I will have to tow it 32 miles to a Cummins shop and wait a few days...I have a call to Cummins of Kenly to see if they will come out and fix, but so far, no return call.
Ivylog
No throttle linkage on a ISL.
deandec
bullydogs1 wrote:
That all makes sense..This guy does know what he is doing and I trust him...But I need to go out of town, which only complicates things..he has the keys, so that's not a problem...where is this solenoid located?...it is a rear radiator ISL and on the right is a door for the secondary fuel filter , levels etc...and on the left is a door for the air cleaner..The primary fuel filter and air dryer are located behind another door...if you can tell me where it should be and the screw to turn. that will get it running at least and I can work on it tomorrow night..your insight and wisdom are very much appreciated..Maybe I can still save this weekend?
Usually connected to the fuel throttle linkage.
Dean
95 CC Magna, Jeep GC
Roman_Duck
Solenoid itself is located on the injector pump, never heard of a by pass screw though
"You never fail until you stop trying!!"
My advice is free but I do consider donations
Ivylog
On a 08 there is no lever. You could try tapping on the injection pump where the fuel line from the lift pump connects on passenger side .
Terryallan
I can't tell you on a diesel pusher. I learned about them in the 18 wheeler world
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
deandec
Just reach in and pull up on the fuel shutdown solenoid arm. If the rig starts, wire it up to run and release it to stop the engine.
I just bought a replacement a few months ago on Ebay for $75.
Cummins West would sell me one for $370.
Dean
bullydogs1
Terryallan
bullydogs1 wrote:
Batteries are at 13.5 v hooked to shore power..The fuel pump definitely is humming for about 40 seconds each cycle...strong cranking..but I don't go longer than 10 to 15 seconds...
A. Local diesel mechanic looking at in the morning.
B. Have CoachNet tow it to a Cummins shop ..last resort..
This came out of nowhere..thing was running like a top when I started it 3 weeks ago no warn lights, no check engine...
Local guy believes it is a stuck fuel shut off solenoid...I can hear the fuel pump going....
It could have been worse...but I'm bummed.
Well, there goes my long weekend....
Thing is, On a Cummins there should be a screw you can turn to open it. You just can't shut it down after you do. Ask your mechanic about it. You can save the tow if he can open the valve / solenoid manually.
Terry & Shay
5.0, 3.73
Lazy Campers
bullydogs1
