help!
wildbill0013
i have spent the last two days replacing a new motor on a single step electric kwickee step, the motor works fine using a battery in both directions but when it is wired to the existing wiring it will only retract, i used a dremel tool with a brass wire brush on every point of ground that the control box uses but still cant get the step to extend when the door is opened. my grounds are showing so much silver i am surprised that ihavent gotten a call from the us mint. i am leaning tordsit being a control box issue as i have power only on the return side and not on the forard side. anyone care to give it a thought as to what to check next? i really dont want to spend another 100.00 dollars for a control box if its something i am overlooking.
thanks in advance wildbill0013.
8 REPLIES 8
MrWizard
Moderator
Moderator
what was the reason for changing the motor
did the old one do the same thing
if yes, then it is a switch problem or controller problem ?
IF no, the motor is wired backwards
shut off power, pull fuse , disconnect battery
try swapping the two power wires to the motor
this assumes all you did was install a new motor, did not change controller
I can explain it to you.
1997 F53 Bounder 36s
ArchHoagland
How to make your signature so we can serve you better:
1. Log on and click "My Preferences".
2. On the "My Preferences" page click the middle box and enter your rig info.
3. Scroll to the bottom and click "Submit Changes"
4. Exit and you're done.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
2000 LEXUS RX300 FWD 22MPG 4020 LBS
US Gear Brakes
garry1p
look at page 37 to test
Page 37 has the procedure for testing the steps this will tell you if you have a bad switch or if it is the controller.
4 way connector pin out is further down.
hope this helps.
Garry1p
1990 Holiday Rambler Aluma Lite XL
454 on P-30 Chassis
1999 Jeep Cherokee sport
jimh406
Did you reverse the connections?
'10 Ford F-450, 6.4, 4.30, 4x4, 14,500 GVWR, '06 Host Rainer 950 DS, Torklift Talon tiedowns, Glow Steps, and Fastguns. Bilstein 4600s, Firestone Bags, Toyo M655 Gs, Curt front hitch, Energy Suspension bump stops.
NRA Life Member, CCA Life Member
dougrainer
1. MORE info needed. year/model of RV
2. It only retracts? Does it NEVER extend? Or does it retract when the door is opened and extends when the door is closed? Doug
azrving
Artum_Snowbird
It sounds like the control box is only sending the +/- signal, and not the -/+ signal. When I worked in the trade, that kind of a problem was often diagnosed as a switch not making. In order for the power to reverse, the forward limit switch must make (or something else like a safety switch makes). I would examine the electrical print, and try to determine how the direction switches, then either jumper out, or open the faulty trigger to check the operation.
Mike
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
darsben1
What about the door switch could it have a bad contact?
Traveling with my best friend, my wife in a 1990 Southwind
