Dec-14-2016 01:00 PM
Dec-15-2016 09:02 AM
Dec-15-2016 08:51 AM
Dec-15-2016 08:16 AM
Dec-15-2016 05:22 AM
Effy wrote:
The only way I have found to prevent it is to physically disconnect the terminals.
Dec-15-2016 03:39 AM
Dec-14-2016 10:31 PM
Dec-14-2016 07:10 PM
Dec-14-2016 04:39 PM
Dec-14-2016 04:38 PM
Dec-14-2016 04:33 PM
doxiemom11 wrote:
New batteries are not always fully charged when you get them. Did you make sure they had a full charge? We stored our MH thru a winter in MI with both engine and chassis battery switch to off. 6 mo later we turned switches back on and everything worked and it started right up. Are you sure the new batteries were installed and connected together properly?
Dec-14-2016 04:28 PM
Dec-14-2016 04:09 PM
Dec-14-2016 02:05 PM
jgmace wrote:
OK, I let it run for about an hour this afternoon. I tried the switch you mentioned, but no luck. Perhaps I didn't hold it down long enough. I'll try it again and hold the bypass switch down for a while before attempting to start the generator.
Dec-14-2016 01:21 PM
