โAug-15-2004 01:22 AM
โDec-27-2015 06:59 PM
โDec-27-2015 06:35 PM
โDec-17-2015 08:07 PM
โDec-17-2015 06:55 PM
regis101 wrote:
True to all dat.
Having the RV has made me learn the importance of single flare for propane and water.
I would not want to use compression for brake lines. I would if I had to get out of da woodz.
โDec-17-2015 05:40 PM
โDec-17-2015 05:23 PM
โDec-17-2015 04:06 PM
โDec-17-2015 09:36 AM
regis101 wrote:
I've been chipping away at the 'ol '73 when time permits.
Discovered the MC was leaking. The hard line that leads to the rear brakes was, cold welded/rusted frozen aint budgin' on the verge of breaking, to the nut.
I did the pb blaster thing for a few days. Kept trying to work the line free with minimal twisting. I then found out about the acetone/atf concoction. Tried that for a few days. Kept everything wet the best I could but being a liquid doesn't allow much to sit there. I left things alone for probably two weeks. Went out there with a pair of pliers to hold the line and a 9/16 line wrench for the nut. Held the line firmly while twisting the nut back and forth and voila, she broke loose.
I cried but nobody saw. The whole ordeal spanned prolly three weeks but I was amazed I was able to save the brake line.
โDec-16-2015 07:10 PM
โDec-16-2015 07:09 PM
โDec-16-2015 06:41 PM
โDec-16-2015 06:07 PM
โDec-16-2015 06:01 PM
regis101 wrote:
Another point to consider is the rubber brake lines. They have been known to get gummy and/or soft on the inside.
As told to me many moons ago, what happens is that when you push on the brake pedal the fluid pushes toward the caliper or cylinder but when the brake pedal is released, the inside of the line collapses thereby keeping the caliper or cylinder in the compressed position .
โDec-16-2015 04:13 PM
โDec-16-2015 03:37 PM
