โAug-15-2004 01:22 AM
โMay-08-2018 11:37 AM
โMay-08-2018 08:39 AM
Eric Hysteric wrote:
Thanks Griff, the PCV line is connected at the PCV Port. In most Edelbrock-threads, people advise to connect the distributor line to the timed vacuum port.
For example in this topic
โMay-08-2018 04:17 AM
โMay-07-2018 07:11 PM
โMay-06-2018 05:25 PM
โMay-06-2018 05:08 PM
RvFNG76 wrote:
small block 360 2 bbl wanna go 4 bbl but havent nailed it down yet. The engine in this monster is untouched except for the egr being removed (plate slightly leaks) by previous owner. Another fun little deal now is speedometer jumps and goes nuts every once in awhile checked the gear in the tailshaft but it looks fine any ideas?
โMay-06-2018 05:01 PM
โMay-06-2018 04:40 PM
Griff in Fairbanks wrote:small block 360 2 bbl wanna go 4 bbl but havent nailed it down yet. The engine in this monster is untouched except for the egr being removed (plate slightly leaks) by previous owner. Another fun little deal now is speedometer jumps and goes nuts every once in awhile checked the gear in the tailshaft but it looks fine any ideas?RvFNG76 wrote:
Well shes finally all legal eagle after being set to the side for a year the ford tires and rims off my f350 performed well. Next is to get the exhaust fixed have a leak on the passenger side where the manifold meets collector. Does anyone have an idea on where i can get manifolds as my drivers side is cracked. Also cam question what would be the best cam to put into the 360
Thanks for the info.
Does anyone know if there's 17" duallies that fit the same Ford trucks?
I need 17" or larger rims to clear the large Kelsey-Hayes dual piston calipers on the front of my RM350. Chevy Silverado dual rims won't work. I want same/same all around and need to replace the 17.5" rims to find the M&S/offroad tires I need.
RE: manifold. Big block or small block? If small block. I may have a manifold in my spare parts collection.
โMay-05-2018 01:52 PM
โMay-05-2018 01:46 PM
I have next question ๐ At my Carter Thermoquad i had a vacuum line from the carburetor to the air pump diverter valve. Now at my Edelbrock 1406 carburetor i have 2 vacuum ports. Timed vaccum port and manifold vacuum port. I use the timed vacuum port for the distributor and the manifold vacuum port is free. Should i connect the vacuum line from the air pump diverter valve to the manifold vacuum port at the carburetor or should i deactivate (cork) the vacuum line from the air pump diverter valve?
โMay-04-2018 01:33 AM
โApr-29-2018 08:24 PM
Fbx-Ak wrote:
It requires a high-pressure fuel pump and a return line to one of the tanks. That means that if you are running off the non-return tank, it has the potential to overfill the return tank. So you have to watch your gauges to be sure that doesn't happen. We can now use an auto-start to remotely start it. You don't have to be sitting in the vehicle pumping the gas pedal to start it on a cold morning.
โApr-29-2018 07:52 AM
Eric Hysteric wrote:The fuel injection is much more responsive and meters gas exactly as needed. Computer controlled and adjustable. No unburnt gas getting into the cylinders.
Fbx-Ak, Holley Sniper fuel injection. How cool is that! What is your experience? Before and after, if you had a comparision between the carburetor and injection.
โApr-27-2018 02:34 PM
StingrayL82 wrote:toedtoes wrote:
I know when I rebuilt my 360, I put in a new 4bbl carb (it had a rebuilt 2bbl). That first trip out, a friend with a 440 was joining me. He couldn't keep up with me.
Good! That's what I wanted to hear (or read, as it were). On the dyno, mine was a beast, but real world application trumps all.
What kind of mileage are you getting with it?
โApr-27-2018 01:46 PM
