Aug-15-2004 01:22 AM
Sep-24-2019 01:45 AM
whiteknight001 wrote:
I'm new here, and curious.
How many of us in Class C own Dodge B300 incomplete
cab/chassis based RV's? I know two others- Steve aka
Ripsaw, with a 1977 Brougham, and Leroy aka 1978_Dodge
_Delta who owns a 440V8 powered sharp looking 1978
Delta RV. I would like to ask, and offer, help, idea
swapping and comparing notes on our particular RV's
which are based on the Dodge B300 van chassis.
Yeah, I know. These are low tech, podgy old RV's that
would be considered "entry level" for folks like me,
but I have a deep and abiding respect for the quality
of these old "monsters of the open road". And anyone
wanting to pick brains, joke about, share notes or just
brag about our old A- Dodge-io's are certainly welcome
to PM or email me. Between all of us we can form a real
good support group, and help each other with problems
we know we'll encounter with an older vehicle.
Sure. I'd love a new RV. But I'd rather have an older
one already paid for, and a lotta great memories. Call
me frugal, an old hippie, or whatever you will. I'm proud
of my old land yacht.
Mopar Madness Manifest in the flesh,
Mark aka White Knight
P.S. Mine's a '72. Is there an older one out there someone's
motorvating in? Maybe even a Travco? W/K
Sep-23-2019 07:45 PM
Sep-18-2019 07:02 PM
Sep-18-2019 03:04 PM
Griff in Fairbanks wrote:
Note: WD-40 really isn't a penetrating oil or a lubricant. It's meant to inhibit corrosion by displacing moisture. (WD-40 = Water Displacement, 40th formulation attempt.)
Sep-18-2019 01:31 PM
You're going to need to pull the control panel, located above the ignition switch. Usually one or two screws on the bottom or sides. Careful, the top is usually held in place by a tab on the panel that goes behind the dash sheet metal. After the screws are out, pull the bottom of the control panel a little bit, then the panel downward a bit to release the tab for the dash. (I've seen people break that tab.)
Look for corrosion or gummy lubricate. A bit of PB Blaster or Kroil, allowed time to work, will free it. (Spray cans can get messy so I sometimes spray on a piece of scrap metal and pick it up with a cotton tipped swab to apply it.) It may take a day or three for the PB Blaster or Kroil, applied repeatedly, to free the slider.
Once it's free, clean with brake cleaner. Re-lubricate, preferably with white lithium grease, and reassemble.
Do NOT use electronic contact cleaner! That "attacks" plastic, causing it to disintegrate.
Go slow and don't force things.
If you get stumped, yell and post pictures.
Sep-18-2019 12:27 PM
Sep-18-2019 12:26 PM
PolCat-76-Avion wrote:
I took out the radio and was able to access the controls. Looks like someone else was in there, white wire tie holding cable in place and the wire is broken. It's a real bugger to get the control loose let alone out. Looks like I will be putting a "choke cable" through the dash and then to the valve. I have a manual for 1976 B100, B200 B300 but not much looks like the MB400. Doesn't even call out the 440 motor only goes to the 318.
Sep-18-2019 12:24 PM
I can slide the wire into the cable but the slide on the dash does not move. I am thinking it is off the slide or broken off the slide.
Thanks
Sep-18-2019 12:09 PM
Sep-18-2019 11:51 AM
Thanks
Sep-18-2019 09:02 AM
StingrayL82 wrote:
Great looking rig! In order to have easy access to the cable, you have to remove center portion of the dash. In my case I was lucky, because our MB300 was not ordered with factory A/C; Monaco installed an aftermarket unit from ARA that was self-contained in a plastic housing....removing the housing gave me full access to the heater components, which was nice because the ducts were completely rotted.
My cable was frozen too, but in my case it was the valve that sits on the heater core that was completely rusted up. If your valve is in good shape, take care of it, because IF you can get a new one, you're going to pay through the nose for it. I was able to find a NOS unit, but it set me back $125.
What I would do is disconnect the cable at the valve and try sliding it back and forth to free it. Shoot some WD-40 into the cable sheath and slide it some more. That should take care of your problem.
Good luck.
Sep-18-2019 07:25 AM
RvFNG76 wrote:
Ok brakes done axle seals done bearings done pinion seal done just finished draining out the gear oil that looked like chocolate milk mixed with garlic mud. Next question is what grade grade oil as it is a limited slip. I do have 3 quarts of 75w90 conventional limited slip oil. Will it work or what's everyone running I've heard the Dana 70 recommends 80w90.
Sep-18-2019 07:11 AM
New member here! Just joined the rv.net site. We recently bought a 1976 Dodge Avion 22 foot rv. MB400 chassis 440 engine. It is in really good shape except that a previous owner painted it with a brush.
Now that it is getting colder I tried to slide the temperature selector to heat but nothing happened. The wire was disconnected from the valve in the heater hose. The valve does work the cable doesn't move. How do I get to the back of the heater control part of the dash?
Sep-18-2019 06:37 AM
Jul-31-2019 06:35 PM
