May-23-2013 06:42 AM
May-27-2013 09:53 AM
MountainAir05 wrote:
As stated, manual set the brake on the toad only and if you do not feel it they are not working.
May-27-2013 09:38 AM
May-27-2013 07:50 AM
The Texan wrote:
If properly set up, you should have NO sensation of the toad braking contributing anything. When properly set, the RV stops its weight and the toad stops its weight, so there is NO contribution from the toad to the RV.
May-27-2013 07:28 AM
May-27-2013 07:02 AM
May-27-2013 04:50 AM
May-23-2013 08:39 PM
Dale.Traveling wrote:
If everything is working correctly you should feel nothing. The braking system should only compensate for the weight of the towed vehicle. The only way I know the brakes are active is when my dash indicator comes on.
May-23-2013 10:03 AM
May-23-2013 09:09 AM
May-23-2013 08:21 AM
djlind wrote:
I am pulling a 5,600 lb. toad with a 23,000 lb MH. The toad has the Unified Brake System installed...
May-23-2013 07:55 AM
May-23-2013 07:45 AM
Bob & Betsy - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever"
May-23-2013 07:41 AM
May-23-2013 07:38 AM
