Sep-28-2015 04:14 AM
Sep-29-2015 05:51 PM
mrekim wrote:
For those that use air.
If you run your compressor just blowing air out for 5 min doesn't the air smell of oil, even if you have an oil separator.
I think an important issue for using air is getting clean air, but I never see it discussed.
2021 Nexus Viper 27V. Class B+
2019 Ford Ranger 4x4
Sep-29-2015 05:09 PM
Sep-29-2015 05:02 PM
Sep-29-2015 04:57 PM
Sep-29-2015 04:29 PM
dodge guy wrote:
Every RV I've seen at RV shows has RV antifreeze in it. So that is how the manuf tests the system and winterizes it. Believe me if a manuf. could save a few bucks on each unit they sell them they would just blow them out, but yet they don't.
Sep-29-2015 02:59 PM
Sep-29-2015 09:20 AM
MagillaGorilla wrote:
Here is my question; If this way is the better way to winterize, why don't the RV places use this method instead of the antifreeze method?
Sep-29-2015 08:36 AM
et2 wrote:
My question is how does the red pop or air pressure feed back through the line coming from the water tank. I never have seen red pop feed back to the water tank. One would think water accumulates their. Unless the low point drain empties that line, which then would explain it.
Sep-29-2015 07:56 AM
Sep-29-2015 07:49 AM
old guy wrote:
I used the air method once and only once. it didn't get all the water out and I had a busted fitting I had to repair, so now I use air and pink. haven't had a frozen fitting since.
Sep-29-2015 07:44 AM
Sep-29-2015 06:33 AM
Sep-29-2015 05:16 AM
Sep-29-2015 05:04 AM
Effy wrote:gbopp wrote:Effy wrote:
Not sure I understand the issue with antifreeze.
I don't think there is a an issue with antifreeze. Just a personal choice.
Many probably don't like the aftertaste of the antifreeze. Even flushing the lines can leave a taste. It may absorb into the plastic pipe. I don't know.
I tried both methods, I like air the best. Just my choice.
I guess it matters if you drink the water. I use bottled water so it's not an issue for me.
Sep-29-2015 04:36 AM
