The rear slide assembly started making noises, then a big clunk and now the motor runs without any motion from the rear slide.
Is there a shear pin on these units? I can't see one from below.
Does the slide need to be extended to make enough room to allow removal of the motor/gear assembly? I can't see how that long steel assembly could be removed with the slide in.
For removal, do you just remove the four nuts that hold the brackets to the frame supports? And also remove the end cap where it attaches to the slide?
Any help or links would be appreciated,
2008 Itasca 30B
I was told the motor and the gearbox are sold together: part number is 148875-01-705, price is 272.40
