HP question on a Cummins 8.3
LongWeekends
So our DP sold and we are shopping for our "upgrade". Engine size is one of the things we want to improve. I see the following in an ad:
"THE 8.3 LITER CUMMINS 360 HP ENGINE HAS BEEN RE-RATED TO 425 HP AND GETS 2 MPG BETTER FUEL ECONOMY. "
Can anyone shed some light on this? What is done to magically change the HP other than some creative typing?
As always, thanks in advance.
Michael
Just me, my wife, our daughter and our two big, hairy Goldens.
18 REPLIES 18
LongWeekends
DSDP Don wrote:
"LongWeekends".....You sold a 2004. If you just buy a year newer, Monaco started putting the ISL 400 in the Diplomat/Endeavor line, and up, in 2005. I wouldn't mess with chipping the 8.3. I'm guessing you saw those numbers in a another forum, possibly "Mr_D" in his old Newmar. Those numbers were NOT from a dyno.
Thanks for the feedback! I saw it in the ad itself, not a forum. It didn't sound right to me so I came here to confirm it. ๐Ÿ™‚
Michael
DSDP_Don
Don & Mary
2019 Newmar Dutch Star 4018 - All Electric
2019 Ford Raptor Crew Cab
supercub
JetAonly wrote:
FWIW we have an 350 HP 8.3 in our Dynasty. We weigh 33k down the road. Without towed my 20k mpg was~8.3 with a 1500 Silverado 4x4 and 500 lb motorcycle in the bed over 10k mile we averaged 7.2. Plenty of HP with out towed. With towed it is adequate. Over Eisenhower tunnel at 11k ft we were about 30 mph. We are about 39k with towed.
The 8.3 was offered in versions to 380 HP from the factory. The transmission is the limiter on most of the 8.3 drive trains. We have the Allison 3066 which is rated to 350 HP and 1050 TQ. The ISL is an 8.3 block with a bigger stroke. It is also a fine engine. The ISL has some years with a bad wrist pin. There is a list of ESN's on this site.o
On my Revolution at around a CGW of 34,000lbs I've average 7.8 mpg in the 14,000 miles I've driven it, all in the western states. It will pull a 6% grade, like the Grapevine north of Los Angeles at +/-45mph and that's without the pedal massed to the metal. I usually back off just a little from full power when pulling a grade, I typically set the cruz for around 57mph.
LongWeekends
Michael
JetAonly
2000 Monaco Dynasty
ISC350
WILDEBILL308
Ivylog wrote:
If you want 425 HP, look for the 8.9L ISL. Without changing the injectors and the turbo a 8.3 is already pushing it's max at 360. In PU's much of the mileage increase by a chip is done by increasing the tire size in the computer... making it LOOK like you've gone more miles than actual.
Where do you come up with this ssstuf. First I have never seen a 8.9 in a pick up. #2 Who would be so stupid not to check their mileage by using mile marker or GPS.
Bill
2008 Newmar Mountain Aire
450 HP CUMMINS ISM
ALLISON 4000 MH TRANSMISSION
TOWING 2014 HONDA CRV With Blue Ox tow bar
A man who carries a cat by the tail learns something he can learn in no other way.
-Mark Twain
Blaster_Man
gswcgi wrote:
I've had 3 Cummins, a CAT and a MB diesel. If the manufacturers wanted more HP or torque or whatever they would have designed it that way. I personally would never buy a DP which the owner messed with the design!!! Just my opinion.
I agree, I've had a Duramax, a Yanmar (in a boat), a Cummins and a Detroit Diesel. They work fine as they come off the assembly line, I would not change one, or buy one that had been altered.
2014 American Eagle
gswcgi
'03 Safari, DP, 36" Nissan 4X4 toad
Ivylog
Sorry, but the 8.3 is not known as a million mile engine at 360 HP... Closer to 600K. If you could get 450 with just a chip it would still last long enough for most.
Upgraded with a 08 HR Navigator 45โ€™...
Tom_Barb
prstlk wrote:
Chipped rigs can also be worth less on trade in or outright sale. Some of us have concerns about reliability. I'd take a box of donuts to your local cummins dealer and ask some questions 360 to 425....thats sounds to good be true.
When you have any engine that is well known to go way past 1 million miles, you can turn the horse power up, and it will still last 500K. ever see a coach go past 500K?
2000 Newmar mountain aire 4081 DP, ISC/350 Allison 6 speed, Wrangler JL toad.
prstlk
2007 Keystone Challenger 5th wheel, Ford F350 Super Duty 6.7L Diesel, Short Bed, 2 dogs and the cat and rolling down the road full time since May 2014
barmcd
I don't think an 8.3 can reliably put out 425 hp. That doesn't mean this particular engine might be unreliable. It might not be putting out 425 hp.
tinkerer
One thing to remember when you do anything to increase the hp of your motorhome you will increase the heat the engine produces and if the radiator remains the same size you could overheat your engine which can be detrimental.
sch911
Another vote for the ISL. Ours is rated per factory specs at 400HP, but can be chipped easily to 450HP.
OEM Auto Engineer- Embedded Software Team
