Feb-12-2017 08:54 AM
Feb-17-2017 05:42 AM
timmac wrote:Effy wrote:timmac wrote:
80 psi is all you need for that size and weight.
This is bad advice and can be dangerous. The ONLY safe method to adjust PSI is to load the MH for travel, weigh 4 corners or at least front and rear and set the cold PSI to the tire manufacturers instructions. Guessing can cause tires to be underinflated and cause serious issues.
Just for your info he has another thread and his specs say 80 psi for the tires from Fleetwood and I also have owned 2 Fleetwood motorhomes with same size of tires and his same length/weight and 90 psi rides hard and 80 psi rides softer and is at factory specs..
So Fleetwood needs sued for BAD ADVICE you saying.. 😮
Feb-17-2017 05:30 AM
Feb-16-2017 03:04 PM
Feb-16-2017 03:47 AM
Feb-15-2017 07:57 PM
Feb-14-2017 05:58 AM
TomKat08 wrote:
Considering upgrading from my 2002 31' Fleetwood Fiesta to a 2007 Hurricane (Thor/Four Winds) 34B. Hoping for a smoother more stable ride. I've owned the Fleetwood for 2 years have added stronger control arms, Davis stabilizers, Safety Plus steering stabilizer, new Bilstein shocks, new tires, etc.. The ride is heads and tails better than it was but. The coach is stable but the ride remains stiff/rough on the poor CA highways. Looking for a softer smoother ride without sacrificing any stability.
Feb-13-2017 05:26 PM
TomKat08 wrote:
LadyRVer
What is puzzling is mine is also built on the Ford F53 chassis. The previous owner replaced the tires in 2014. On the sidewall of the tires it says minimum air pressure is 100 lbs. On the placard on the drivers side wall it says 80 lbs. I think I'm going to post the type of tires and ask for feedback. It may very well be I've got cheap hard - overinflated tires causing the rough ride.
Feb-13-2017 05:16 PM
Feb-12-2017 12:24 PM
Feb-12-2017 11:39 AM
