Hydraulic cylinder protection...is it needed?
Teeshot1939
I have the HWH hydraulic leveling system and will have my 4 jacks fully extended and exposed to the elements for 1 or more months. Should I apply a spray lubricant or protective spray to the exposed cyclinders? If so, which would you recommend and why? Would it be better to operate the levelers every couple of weeks? Thanks...
19 REPLIES 19
bobkatmsu
Use silicone spray and not WD 40. it attracts dirt. silicone does not.
2010 Newmar Dutch Star DP
2014 Jeep Wrangler Sahara
ScottG
Ordinarily those cylinders are not going to rust but we all know they make things as cheaply as possible on RV's.
It certainly wouldn't hurt to put a little something on them - just for insurance.
Halmfamily
My Kubota is nine years old and had sat in the weather for half it's life and now sits under a shed. Hydraulic rams look perfect and work perfect and never put anything on them. Same with my fifth wheel. They're designed for the elements.
2008 GMC Sierra 3500 SLT DRW D/A 4x4 (Big All)
2006 Ford F350 PSD SRW King Ranch 4x4 (Henry) (Sold)
B&W Companion, 90 Aux Fuel Tank, Scan Gauge II, Curt f/m hitch, Swagman XC
2015 Forest River Sierra 360 PDEK
DW Diane, DS Michael, FB Draco and Sabian
dougrainer
1. Just make sure they stay clean. Just hose them down if blowing wet debris gets on the silver piston
2. You do need to cycle them twice a month. This keeps the seals moist and flexable.
3. You also need to cycle your slide rooms twice a month also. Hydraulic or electric. Doug
Trackrig
I think MH people worry too much, look at all of the heavy equipment and farm equipment sitting out there with exposed hydraulic cylinders that are never treated with anything - and yours are under the MH not sitting out there in the elements.
Having said that, I spray mine with silicone spray every couple of weeks and usually when raising them if they've been down for a couple of weeks. Makes me feel good and doesn't harm the cylinders.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
