โJan-19-2018 07:14 PM
โFeb-15-2018 02:55 PM
J-Rooster wrote:
Joe, you asked a great question! When Iโm not in the Southwest for the winner, I store my motorhome along side my stick built house and my RV is plugged into my 50 amp plug in. This is just what I do Joe because it works for me! I change oil in my coach so the crankcase is sitting in fresh oil. I have a solar trickle charger that charges my coach batteries (two batteries) My engine compartment battery does not have a trickle charge so I start it once a week. I drive my coach 20-30 miles the purpose for this is to have the engine oil circulating thru the engine, and the water system circulating. And it warms up the oil in the rear differential and transmission. Anywhere, else I might not go thru all this, but in Western Washington State it rains a lot the humidity is around 88% so everything is just damp! So I guess what Iโm trying to say is Iโm anti condensation! Also, Joe while in storage I leave my leveling jacks down to take weight off the tires and I use wood, rubber or plastic between the tires and the ground. Good Luck to you on whatever you choose to do! I also use a dehumidifier to keep moisture off my front windshield, If I donโt do this then water will drip down on to my inside windshield bracket holder and rust it out. Drier climates this is not necessary. Rooster
โFeb-09-2018 06:55 PM
โFeb-09-2018 09:55 AM
โFeb-06-2018 01:13 AM
wvabeer wrote:
I removed my batteries in November to keep them above freezing and on a trickle charger. If I remember the owners manual suggests it. I'll reinstall them sometime in April.
โJan-31-2018 12:54 PM
โJan-30-2018 07:43 PM
โJan-22-2018 02:47 PM
10forty2 wrote:
One more opinion to NOT start it and let it just idle.
โJan-22-2018 08:52 AM
DrewE wrote:
If it's generally cold, you can safely charge the batteries fully through whatever means is convenient and disconnect them entirely and they will easily survive the winter without self-discharging overly much. If they are dead in the spring, they were already on their last legs.
This is not a good idea if the temperatures are warm. The rate of self-discharge is quite temperature dependent; a few weeks at 90ยฐ is worse than several months at 10ยฐ.
โJan-22-2018 06:40 AM
โJan-22-2018 06:24 AM
โJan-22-2018 04:51 AM
Mile High wrote:
and hold the voltage right about 14V.
โJan-21-2018 12:05 PM
rowekmr wrote:Ah, I didn't understand that. I didn't have electricity last year, but lucked out because the owner installed it for the asking. Without it, I would have taken it for a run at least monthly to avoid harming the batteries.
My storage lot has no electricity.
โJan-21-2018 09:59 AM
โJan-21-2018 07:11 AM
