Jacks down during winter storage?
hoopers
Just wondering what people recommend regarding leveling jacks.
During winter storage, should one keep the leveling jacks down, or up?
In the storage lot, I see examples of both...some motor-homes with the jacks down, and others, just sitting on the tires during winter.
Thanks for the help.
2014 Winnebego Vista 30T
2017 Ford Expedition
Texas gulf coast, Colorado, or on the road camping somewhere
28 REPLIES 28
WTD44
I park on a level pad, put 4 X 8 's under each jack pad, lower the jack a few inches to it just touches the 4 X 8 and than let out about 50 # of air.
WayneD
'07 H.R. Scepter > P A Q
Cummins 400 ISL
Alison 6 speed World
08 CR-V
Wife and,
Sparky the Wonder Dog
katoomer
SAR Tracker wrote:
robatthelake wrote:
I have never seen Stainless Steel Hydraulic Rams Rust,even in the Salt air environment at a Mexican Beach!
No, but the first time it's retracted after several months of crud accumulating on the cylinder, the cylinder, rod, and/or wiper seal is just about sure to be destroyed.
So then just wipe them down before you retract them
2009 Newmar Ventana 3942
2010 Pace Shadow 18ft
2010 KTM 450 XCW six days
2010 Can Am Outlander 650 XT
2014 Can Am Outlander 500
2007 Yamaha YZ250F
1989 Douglas Skater 21' Twin 2.5s
dezolen
Obviously it really does not matter. Personal preference.
I like to take the weight off the suspension and tires. Also might even prevent overloading a tire should one loose air for some unknown reason,especially when one cannot check coach on daily basis. To me it's common sense if there is such a thing these days.
Snomas
golfknut wrote:
My manual says to leave them up.
X2
2006 WINNEBAGO ASPECT 29H Ford E450 Super Duty
2018 F150 Lariat Crew Cab, Coyote 5.0 L RWD
bshpilot
when i store our coach (even if its for a week or two) i lower the jacks enough to get the tires off the concrete in our storage bay.
I got sick in march, took one trip in May (to see my son commission w/ the Navy) & the coach has been "in the air" (off the tires) every since, until just last week.
Don R.
'04 42' Haulmark Motor Coach - 450hp/1650tq / 12 spd SmartShift
'12 Jeep Wrangler Sport (manual trans)
'17 Platinum F350 (6.7L, SRW, CC, Long bed, 4x4)
robatthelake
I didn't say not to clean the Jacks ,just that they don't Rust!
Rob & Jean
98 Dutch Star Diesel Pusher ..07 Honda CRV AWD
frankdamp
The system on my MH does have seals at the bottom of the cylinder, as the retraction is done hydraulically, not with external springs. The first off-season after buying the coach, I extended the jacks when we parked it (in a third driveway at the S&B). Within 10 days or so, there was evidence of corrosion starting, so I cleaned it off and retracted the jacks.
I've tried raising the rig one side at a time and rotating the wheels 120 degrees once a month or so, but rotating the duallies is hard work. I was considering the heavy-duty jack stands for this off-season, but we're going to put the rig up for sale, probably at a consignment dealer about 20 miles away. The hobby has just become to expensive to afford.
Frank Damp, DW - Eileen, pet - female Labrador (10 yrs old), location Anacortes, WA, retired RVers (since Dec 2014)
PortWentworthSa
I bouught 4 heavy duty truck jack stands. I raise my coach with the leveling system and then put the jack stands in place. lower the coach, usually only 1", onto the jack stands and raise my levelers.
Easy to do and saves the leveling jack system. Works for me and can do it in 15 minutes.
The 4 jack stands run about $125.00 (for big trucs) and I use them all the time.
Popsie
We were full timers for a number of years, and spent every night with the jacks down.
Now we spend an average of four winter months a year in Arizona with the jacks down, and they are down another few months of the year while we are traveling.
Right now, the RV is in a storage lot with the jacks down.
I've never done anything to clean or lubricate the jacks.
YMMV
the_silverback
Michelin and Goodyear recommend yes, jacks down. Get some weight off the tires.
the silverback
2015 crossroads Rushmore 5th wheel
Effy
hoopers wrote:
Thanks for all the comments. I didn't see anything in the owner's manual, but will check again. Mine is a gasser class A, and doesn't have the air suspension.
I am leaning towards retracting the levelers, and just leaving it on the tires.
The comments reflect what I see in the storage lot...some people put the levelers down, while others don't.
Call Winnie
2013 ACE 29.2
hoopers
Effy
67Cutlass wrote:
You should read the manuals that came with your RV. Then do what the manufacture recommends.
x2
2013 ACE 29.2
67Cutlass
2012 Phaeton 40QBH
2015 Jeep Cherokee
SMI Air Force One
Retired USAF - CEVG and AFTAC
Member of Tiffin RV Network Forum
