Jun-19-2013 12:53 PM
Jun-21-2013 06:53 AM
Bordercollie wrote:
Regular dump setup is OK, takes no more than ten minutes to do, keep latex gloves handy, wash hands well afterward and go on with your life.
Jun-21-2013 06:48 AM
Jun-21-2013 05:11 AM
happybooker1 wrote:My primary concerns with the "Sewer Solution" type of sewer management system is that you need to hook up fresh water to run it. That involves another garden hose to carry that needs to be labelled "Bio-Hazzard" and must be stored accordingly. I would be concerned of it accidentally getting used for fresh water. You know what it's for, but someone else trying to help out may not quite get it.
Or get This
Jun-20-2013 08:08 PM
Jun-20-2013 07:52 PM
Bordercollie wrote:
Before you do dump holding tanks: Make sure that your sewer hose is in good condition and has end connectors properly installed. Have a small low stool to sit on while you connect the sewer hose to the RV dump outlet.(Camping world sells small collapsible stools). Put on latex gloves, make sure that you turn and latch hose connector securely to the RV. Insert sewer hose securely into sewer so it can't come out and spill all over. Place a rock etc. against the hose. The bigger dump handle is for the black (toilet waste) water. The smaller dump valve handle is for the grey ( sink and shower waste water). After you dump the black water tank, close its valve and open the gray water valve and wait until it stops draining. Disconnect hose from RV. If rinse water is available run clear water through sewer hose to flush out any remaining stuff and let it drain out completely, then put sewer hose away. Rinse any remaining stuff into the sewer if at the communal dump. Remove latex gloves and put into trash. Leave nothing behind for the next user. Wash your hands thoroughly and congratualate yourself on a job well done. Some RV owners never use their own RV toilet for fear/distaste of dumping chores, don't be a lily.
Jun-20-2013 07:21 PM
Jun-20-2013 06:23 PM
Jun-19-2013 05:57 PM
Jun-19-2013 05:34 PM
ron.dittmer wrote:
This process must be done just prior to the start of "Every" camping season.
Jun-19-2013 04:28 PM
Jun-19-2013 03:19 PM
Jun-19-2013 03:11 PM
Jun-19-2013 01:46 PM
Jun-19-2013 01:31 PM
