K&N filters
Maw__Jim___Jake
Are the K&N air filters worth it?
Tanks
2008 Newmar Grand Star, Brake Buddy, Blue Ox, Explorer Sport Trac 4x4, and (one brilliant Golden Retriever in spirit and memory) Toby our Corgi pup.
42 REPLIES 42
mikeleblanc413
That's good to know about the V-10. That is the engine I now have in my Winnie. Used K&N on a Dodge Dually...not good, not bad, expensive. Use WIX now and am pleased.
Mike LeBlanc
The Piney Woods Of East Texas
Lufkin, Texas
2oldman
no
352
Do not use on a diesel.
The manatees of Halls river Homosassa Springs Fl
1985 Chevy Silverado c10. 454 stroker / 495 CI = 675 HP. 650lb of torque. Turb0 400 tranny. 3000 stall converter. Aluminum heads. 3 inch exhaust flowmasters. 2 inch headers. Heat and air. Tubed.
Desert_Captain
Nothing wrong with K&N filters if you are smart enough to follow the instructions regarding oiling/re oiling the filter element. When folks say it fouled their MAF sensor it is an admission that they over oiled the filter. :S
I have used them for years with good result (the last time my mechanic went to clean the throttle body it was immaculate), and they pay for themselves vs buying pricey paper filters, after a couple of years.
As always.... Opinions and YMMV.
:C
j-d
Correct spelling is GiMMick. That's with two M's.
jfkmk
PRodacy wrote:
I've used them for years. Saved lots of money not buying throw away filters. The K and N filters seem to have coarser holes than disposable ones, so they actually filter better once they Cole t a little dirt on them.
And until the filter starts to get a little dirty, those coarse holes are letting lots of dirt through.
Dakota98
As far as I'm concerned K&N amongst all the other similar intakes are less restrictive than stock. I do think they allow the engine to breath & perform better but other than that, I have never noticed any increase in mpg. As far as clogging the mass air, that will occur if too much oil is used when servicing the filter. I do have to say, having added my K&N along with "Cat Back" exhaust the truck performs much better when towing. Those two enhancements work well together. IMHO
I'm an expert in only one field....I believe it's somewhere in Kansas.
2000 / 22' SKYLINE NOMAD LITE
1998 DODGE DAKOTA / 5.2L= 8mpg.
2006 POLARIS ATV
1500/1200 Watt Champion generator
Yada Wireless Back Up Camera
1998 Dyna Wide Glide
USMC 68-74
Oldme
I have seen a lot of posts of other forms
both pro and con. I have used one on my car
awhile back.
From reading, the K&N does not filter the smaller
particles that damage valves etc until it is dirty.
Instead of using a K&N or buying one of the expensive
ram kits, for my V10, I just took off the
front of the filter housing so the filter would be exposed.
I have had no issues in major down pours getting the
filter wet and causing problems.
Did it help?
It sounds Lauder (old gear head likes that) like an open
air filter on a muscle car.
On my Class C and towing a Dolley with CVR I average 8+ MPG.
As they say your millage may vary.
donn0128
Lots of information on them. Most undetstand they are a waste of money. Air flow studies show them to actually restrict air flow.
nomad297
midnightsadie wrote:
put one in my V10 rv and it clogged up the mass air flow sensor.
Had the same thing happen on my Silverado.
Bruce
2010 Skyline Nomad 297 Bunk House, 33-1/4 feet long
2015 Silverado 3500HD LTZ 4x4, 6.0 liter long bed with 4.10 rear, 3885# payload
Reese Straight-Line 1200# WD with built-in sway control
DirecTV -- SWM Slimline dish on tripod, DVR and two H25 receivers
midnightsadie
PRodacy
2012 GMC 3500 dually 4x4
2006 OKanagan 90W
2003 Jeep Rubicon, modified for off road performance
Had one on my F-250 V-10... felt or noticed no difference.. Except for the missing $$$$ from my wallet after paying for it , and maintaining it with the oils . .
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
