โDec-09-2013 03:50 PM
โDec-11-2013 05:40 AM
โDec-10-2013 05:38 PM
C-Leigh Racing wrote:rad valve wrote:ricardo wrote:
Rad Valve posted an interesting link. Steel gears but variable shaft lengths. Any one know the shaft lenght needed. I was hoping not to pull the motor before having the replacement.
The 210 and 214 motor is what Kwikee used on the steps. They started using those smaller motor in around may of 2002 and switch to the larger motor in 2004.http://www.amequipment.com/ame-products/utility-gearhead-motors/
Just noticing your screen name, where did the idea Rad Valve come from ?. Is it like in Boysene Rad Valve.
Neil
โDec-10-2013 05:23 PM
Bumpyroad wrote:ferndaleflyer wrote:
I changed mine with a Dorman power window motor for a Ford from Autozone---drivers side front if I remember right $29.00 with lifetime warranty.
are you sure they would give you a lifetime warranty if they knew you were using it for another non-approved use?
bumpy
โDec-10-2013 04:00 PM
โDec-10-2013 01:45 PM
bumpy
โDec-10-2013 12:07 PM
โDec-10-2013 10:22 AM
โDec-10-2013 06:41 AM
โDec-10-2013 06:25 AM
โDec-10-2013 06:19 AM
โDec-10-2013 05:42 AM
โDec-09-2013 05:38 PM
โDec-09-2013 04:35 PM
โDec-09-2013 04:25 PM
ricardo wrote:
Well I experienced the unfortunate event of someone pulling alongside and waving that our steps were down. After trouble shooting I determined the motor is bad. I have read that an auto power window motor is a direct replacement but how do I determine which one is correct? Are all the steps using the same motor? I found no informatiopn on the motor itself but of course there is a part number (9010000220)for my two step Kwikee. There is also a pin # 151000014 on the control board housing. Thanks in advance.
