Levelers down and still hooked up to my dinghy
Bednarski1
New to the great life of RVing. I have a 2014 Sunseeker and pull a 2012 Equinox. Just wondering when I stop for the night and don't unhook and put down the levelers will that do anything to the tow bar or my dinghy. Thanks for all the great feedback.
11 REPLIES 11
Horizon170
Double post.
Marvin
2010 Coachman Freelander 22TB on a
2008 Sprinter/Freightliner chassis
1995 Geo Tracker (Toad)
Horizon170
Leave the Toad in travel position, hooked up. You can extend levelers to their MAX and it will not affect the Toad.
Marvin
rvten
Leave our toad hooked on all the time. On over night stops.
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008 Type C
Ford Flex SEL 2010
There is NO B+
rmmpe
I've done it many times. Just make sure you leave the TOAD in the tow-ready condition so it can move around as needed when extending the jacks.
Bob (Squidly Down Under) & Peg
"In God we trust"
2013 Ford Focus pushing a 2011 Phoenix Cruiser 2552S
Carry on, regardless...............
tropical_ron
No issues except...don't forget to put car in park and take keys out, you could be surprised with a dead battery the next morning. We have on occasion used jacks to level off THEN put car in park, once the motorhome is level, and remove keys for the night. In the morning my routine is to run car through the gears and end up in neutral and the ignition in acc. for the days travel. My 2-cents.
2007 National Tropical T370 LX CAT-350
2010 Honda CRV awd
Blue Ox Baseplate
SMI aux. brake
past-MIdirector
Never had a problem and have seen plenty of rigs in pull thru sites with tows still attached! Just make sure the back of the vehicle is not out in the driveway!
Tom_Barb
It will have no more effect than traveling the back roads that cause the coach to sway.
j-d
Unless you park the coach way off level you should be fine. I kinda doubt you could raise levelers enough to match what can happen while towing.
rv2go
I have done this several times when just parking for an overniter.
Winnebago Journey
TN Lic. RV 2 GO
Jeep Cherokee 4x4
I'm here #4335
Blog
Mich_F
Why not (just to be on the safe side) unhook the car before you level the unit, why take a chance ?
2014 Itasca Spirit 31K Class C
2016 Mazda CX5 on Acme tow dolly- 4 trips ~ 5,800 mi
Now 2017 RWD F150 with a drive shaft disconnect
Gene_in_NE
Would depend on how far "out of level" you might be parked.
2002 Trail-Lite Model 211-S w/5.7 Chevy (click View Profile)
Gene
