โJun-24-2013 08:38 AM
โJun-24-2013 03:41 PM
โJun-24-2013 02:32 PM
โJun-24-2013 11:40 AM
Bruce Brown wrote:
I made a few. I bought a sheet of 3/4" plywood and cut it up into (18) 16" x 16" squares. Next I used Liquid Nails and deck screws and laminated them together - some 2 pc, some 3 pcs. That gives me a nice varity of 1.50" and 2.25" thick pads.
I also put 1" holes in each of the corners so I can use my awning rod to pull them back out when I'm packing up.
I did this about 10 years ago and they're still as good today as they were the first day.
โJun-24-2013 11:27 AM
โJun-24-2013 11:21 AM
FIRE UP wrote:
Grover,
As you can see and read, many folks have different ideas on what to use and whether or not to make them or buy them. It's all a matter of opinion. As long as they're stable, strong, non-slip type blocks, anything will work. I carry a small lumber yard with me. I've got (4) 4x10x20 that are beveled at one end. Those are primarily for the rig to drive on in the rear if, the rear is low when we enter a campsite that may need that kind of augmentation.
I also carry some 2"x10"x20" that are sandwiched between two 5/8" Birch plywood for additional leveling (primarily for the front wheels). And finally I carry (4) 11"x9" solid lumber, also sandwiched between the same Birch plywood for the jacks. Yep, it takes up a bit of room but, it's there for a purpose and, almost all of it is used on a fairly regular basis. I'm one of those types that does the "primary leveling" with the tires and wheels and use the jacks for "fine tuning" type thing.
That little lumber yard has come in handy way more times than you'd think. I've installed "eye bolts/screws" on all of them so a little bent arm can retrieve them when it comes time to pack up and move on to another sight. Way easy that way.
Scott
Those are impressive and nice workmanship too. I have never seen wood thicker than a 2X for sale around here unless it is pressure treated or bought direct from the Menonite sawmill. I don't see the ramps on the blocks in the pictures, how do you get up on them?
From the responses it sounds like there could be market for a retired person making these as a hobby.
โJun-24-2013 11:12 AM
โJun-24-2013 09:51 AM
โJun-24-2013 09:39 AM
โJun-24-2013 09:23 AM
Fishinghat wrote:
I made some using 6X12's. They are about 2 feet long and tapered on one end so I can drive up on them, like a ramp. The disadvantage is they are on the heavy side.
At one favorite camp site, I have to use two of them on the front right corner to level my coach. The leveling jacks just won't raise the corner far enough.
โJun-24-2013 08:52 AM
โJun-24-2013 08:50 AM
