Jun-22-2013 05:06 PM
Aug-15-2013 12:39 PM
eric1514 wrote:
True, but it seems that a leveling system using manually pumped bottle jacks would be inexpensive and popular for smaller RVs. Harbor Freight sells 20 ton bottle jacks for $40. 4 of those, modified for quick extension and frame mountable, and you have a leveling system for under $500. I'd buy one 'cuz I'm too unskilled to make one and too cheap to pay $3000 for an automatic version.
Aug-14-2013 11:19 PM
eric1514 wrote:Westronics wrote:
I use four permanently mounted BAL scissor jacks. Works great. You can level the rig - but never, ever, lift a tire off the ground with them. They do not have enough lateral stability for that (yes, I do have first-hand experience with that!).
Boy, some pics and more details of that would be welcome.
I assume you're shifting the body around on the suspension since you're leaving the wheels on the ground. How much travel do you think you get? Do you use blocks under the jacks to minimize cranking?
Inquiring minds want to know,
Eric
2002 Jayco Greyhawk 24SS
, Camera, ScanGauge, Inverter, Airtabs, Portabote, SeeLevel II, Tireman valves, Xatnrex Battery Monitor, Aero-flo vent, Trik-L-Start, XPS Rib, Chains, Lil' Stanker, Be kind to septic systems Ford: 1-800-444-3311. RV TiresJun-26-2013 05:53 AM
Jun-25-2013 08:58 PM
Jun-25-2013 08:29 PM
Jun-25-2013 06:08 PM
Jun-25-2013 05:03 PM
Jun-25-2013 03:49 PM
Jun-25-2013 11:06 AM
, Camera, ScanGauge, Inverter, Airtabs, Portabote, SeeLevel II, Tireman valves, Xatnrex Battery Monitor, Aero-flo vent, Trik-L-Start, XPS Rib, Chains, Lil' Stanker, Be kind to septic systems Ford: 1-800-444-3311. RV TiresJun-24-2013 05:41 PM
Jun-23-2013 09:08 AM
GrumpyandGrandma wrote:
The manual jacks are stabilizers, not levelers.
Jun-22-2013 06:41 PM
