Locked out of RV
marbilupton
We are locked out of our rv. Waiting for locksmith to come and make a key. Anyone with similar experience? What was outcome?
Retired Navy, 39 Years
2005 Winnebago Voyage 35D
2006 Honda Crv
Blue OX Alexus Tow Bar
Brake Buddy
34 REPLIES 34
acker1
rgatijnet1 wrote:
The dead bolt portion does not fail,
I had one fail on my previous MH. The tailpiece that turns the bolt broke in half.
DICK
40' 2010 Phaeton QTH
toad--2013 GMC Sierra Crew Cab pickup 4X4
Viet Vet '65, Ia Drang Valley survivor (We Were Soldiers)
Elks
www.4ezdaz.com Same site, different URL
gsf35099
We had a problem with the door locks & fortunately were home. I was able to get a ladder and open a side rear window and climb in. In the end, turned out we were using the wrong keys in the locks. Little to much to drink that day.. LOL:S
2005 Damon Astoria 3679
300 Cummins ISB 5.9, Allison auto 5 speed
Life is to short not to have a good time and enjoy!!!
wa8yxm
Assuming you locked keys inside motor home two suggestions.
First, I took a common mechnic's "Seal Pic" the one I used was L shaped, and managed to depress the striker bolt when it broke and locked me out in such a way that no key would help.
Second: Have your locksmith make you spare door keys, and sell you a Realator's bo (Key Safe) mount the key safe somewhere you can not lock (propane bay?) and do not forget the combination (i did)
msmith1199
Bill Hamilton wrote:
Drill a very small hole in the frame of the window {any window that slides}right behind the lock that prevents the window from opening. Then push a rod {drill bit or other} and unlock the sliding window. Wiggle the rod to push the catch up. Then slide the window and crawl in. When finished, put some black {assuming the frame is black} RTV in the hole to seal it up. If it happens again, you already have the hole that for all intensive purposes, no one will ever know is there.
But my drill is locked in the motorhome with the keys!!
2021 Nexus Viper 27V. Class B+
2019 Ford Ranger 4x4
Bill_Hamilton
2006 Safari Simba
Gone 2005 31W Fleetwod Tioga SL - Not my problem anymore!
1996 Jeep Cherokee Toad
kalynzoo
We were lucky, while at the beach with kids and grandkids the door closed and locked, perhaps because the grandkid(s) flipped the switch before closing the door. The lucky part was the bathroom window was open, and the 7 year old was small enough to be lifted and put through the window. He saved the group and was given applause and cheers when he opened the door. Fun memories.
We now hide a set of keys.
wallynm
Door lock
On our 02 DSDP - When we stopped for fuel we could not unlock the dead bolt lock. We disassembled the lock from he inside and we able to open the door. The dead bolt is still inside the door and has dropped down inside the door and now we can not use the key to lock the door for the door handle either from the inside or outside. Any suggestions or has any one ever took the door apart or had this problem
Later, We disassembled the door and determined the dead bolt had dropped down into the door latch assembly. This happened because when I had a problem with the tumbler part of the door lock I removed it and put it in a plastic bag for safe keeping. This allowed the dead bolt to move around in the door due to road vibration. I should have reinstalled the tumbler parts and taped it in place on the outside of the door until I could get it fixed.
I tried to find replacement parts in the Kansas City metro area and was unable to find either parts or a new dead bolt lock the would fit. It is not a standard size door lock. In the end I had to order a new lock assembly from Newmar.
They must think it is gold plated as they charged a $169.00 for the dead bolt lock set.
Have a Diesel Engine Diesel RV Club
Have a Freightliner FCOC Web Page
Living on the memories now
EX 02 DSDP 3567
EX 99 Coachmen
EX 86 Georgie Boy
EX 75 Winnie
EX 72 Sightseer
EX 68 Brave
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
msmith1199
Gonzo42 wrote:
This kind of thing kinda/sorta bothers me about the newer class A MH. Most of the ones I see have only one door, as the driver and front passenger doors have been eliminated. Makes me nervous.
Newer Class A's??? I don't recall a time ever when most Class A's had more than one door. I think I recall some older Winnebago's maybe that had a drivers doors up high. I'm sure there are probably some Class A's out there someplace with more than one door but the vast majority only have one door and it's been that way for as long as I can remember.
sdianel_-acct_c
we called the dealership where we bought our RV and they had a master key.
Fortunately we were near the dealership when it happened. They made sure we were the owners before they let us in! Since then we made an extra key and always keep one with us.
Lonny & Diane
2004 Country Coach Allure 33' "Big Blue"
Towing 2008 Chev Colorado 4x4
Semper Fi
Matt_Colie
When you get through this, look up "Hide A Key" and put a door key somewhere that it can be retrieved when needed. Or, use Duck Tape to put a door key inside an non-locking external door/cover/panel.
We have done and used both methods.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs (one dear dog is waiting for us at the bridge) going to see some dry places that have Geocaches in a coach made the year we married.
Bob_AnnaMarie
We had this happen on a stop in Mesa, AZ. Fortunately it was the trimark lock versus the Kwikset lock. Locksmith had no problem opening the coach. (He was the one to say that he was glad it was the trimark lock versus the Kwikset.)
03 Beaver Patriot
14 Honda CRV
randallb
Lube your latch on a regular basis. This keeps the internals from breaking.
dtgunner7
A good lock smith can pick the lock, lost my keys and locksmith came and picked the lock. Then made us several keys from master in coach
RoyB
We solved our lock problem by have our second set of keys available from the truck. My truck has the push-button Key DOOR lock so is always available to gain entry as long as the battery is working I guess...
I do know the aluminum frames of most RV trailer allow you to use a heavy duty scrwdriver and can spring open almost any door without doing damage to the frame.
Gaining access to the storage bays would be where I would go with my 5th wheel. It has a laundry drop from the bed room area and small person can crawl up through that and open the doors from the inside. Don't know if your motorhome has that or not...
Also when camping it is a blessing sometimes to be around the other campers as most of the key blanks are the same especially for the storage bays etc... That happened to me one time and this is when I implemented the second key ring always inside the truck glove box.
Using the screwdriver on the storage bay door will only bend the inside lever of the storage key lock with is easily fixed or replaced from any hardware store. Of course if you have no way of getting inside the trailer from the storage bay you wouldn't want to force open this door...
Just passing along some of my thoughts.
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
Gonzo42
In Hollywood, a starlet is the name for any woman under thirty who is not actively employed in a brothel. --- Ben Hecht
MOTHER SHIP Winnebago View 24H (2007 Dodge Sprinter 3500 Chassis, 2008 Body)3.0 L M-B Diesel V6 bought used with 24K miles. Toad: ROCKY the Flying Squirrel.
