Nov-19-2013 09:01 AM
Dec-05-2014 03:49 AM
Pop-Pop C wrote:
There are no adjustments on RV water heaters.
Why..?????? I'm not sure.
Dec-04-2014 05:57 PM
Dec-01-2014 05:53 AM
Nov-30-2014 07:49 PM
werni9 wrote:
I am in agreement with you all on the Tstats. I have an Atwwood. No hot water on electric. LP great. Breaker-good. switch-good......What would be next? I have GCH10A-3E 10 gal. Elec/lp combo. Don't know if I have the 3rd option besides those 2 options. Something about an Engine Heat source to heat water. Would TStats be next to check for current? Pull unit out and check connections on heating element? Check heating element itself? (screw in design) One thing is a voltage meter wall monitor doesn't twitch when I flip the interior on/off water heater switch on. There is an on/off switch on the right side of the back end of the unit. I'll check and hope you have some ideas. Unit is 14 years old. Change check valve 3 months go. All was fine. Trip to Texas and it worked a month and then the no hot on electic. I know what you are thinking......messed around in there and now...a problem. Hopefully loose connection. Bob
Nov-30-2014 01:50 PM
Nov-19-2013 03:47 PM
Nov-19-2013 02:23 PM
Nov-19-2013 01:52 PM
Nov-19-2013 12:04 PM
joraz wrote:
Thanks to all. I did call Atwood and they confirmed the normal 140 degree non adjustable temp. We don't have kids; I was just thinking it was very hot. Though I could adjust it down so it wouldn't remain on as long as it does. I'm going to measure it today and see if mine is set to the 140 or 180. BTW, Atwood was quick with a return call from a knowledgeable person.
jor
Nov-19-2013 11:54 AM
Nov-19-2013 11:52 AM
Nov-19-2013 10:34 AM
Nov-19-2013 09:57 AM
Nov-19-2013 09:21 AM
