โApr-05-2016 06:57 PM
โJul-26-2016 09:50 AM
โJul-26-2016 08:40 AM
โJul-26-2016 04:54 AM
just want to ride wrote:
First of all, I have the Michelin XRV's on the front and Toyo M154 on the rear at Les Schwab's suggestion. I got the coach weighed and inflated tires per Michelin chart. Last trip out I still had the wandering trouble and the wind moves us where it never did before. I am thinking it was a mistake to let Schwab talk me in to the Toyos. Someone suggested the jeep is pushing me around but i doubt it. I appreciate all of the input on this subject.
I have a 2000 35 foot Holiday Rambler Endeavor. I recently replaced all of the tires with Michelin 255-80-22.5 XRV tires. I recently took a trip about 800 miles round trip. I am running 100 PSI in all tires
(max is 110) The motor home seems to want to wander. On the old tires you could drive with one hand but the new ones require all of your attention to stay in a lane. I was flat towing my Jeep so no additional trailer tongue weight. Anyone have any ideas ? I have been told they will wear in and stop wandering but I'm skeptical.
Ivylog wrote:
If I have this right, four months ago you put Michelins all around and now you replaced the rear four with Toyo on your 2000 HR? You are still having handling problems. Having run Toyo's on a previous MH, they are not your problem. New tires can take awhile to break in... I know it's easy for me to say give it some more time, but that is what I would do.
โJul-25-2016 07:40 PM
โJul-25-2016 04:35 PM
โJul-25-2016 04:23 PM
โMay-13-2016 09:07 AM
โMay-13-2016 08:33 AM
โMay-12-2016 07:59 AM
โApr-06-2016 11:54 PM
โApr-06-2016 09:46 PM
โApr-06-2016 09:26 PM
Jim & Betty wrote:down home wrote:
The Michelins ride better than truck tires or the GY670sbecause they have softer sidewalls.
We put Michelins on the steer axle and are considering whether to do the same n the drive axle.
We follow the inflation recommendations on the motorhome behind the drivers seat.
Maximum pressure beat us to death, and loosened some things up. We don't carry, that is most of don't the heavy loads for those pressures like a semi.
Soft side walls means more squirm beside the softer ride though.
I am thinking hoping the same tire on both axles will even out the tendency to squirm around.
I read every post about tires on motor homes trying to keep abreast of what is working for everyone.
I don't think I want to go back to a stiff tire on steer axle unless we put some lead in the front end though.
Steer Safe and soon may be the way to go.
I'm going to keep reading here and see what is working for others.
It's not much fun using the stering wheel as a tiller.
Down Home
You need to follow the inflation recommend by the tire manufacture after weighing the RV preferably at all four corners.
How does the RV manufacture know what tires you will install on your RV that they can give you a recomendation on tire inflation?
Just because a tire says maximum inflation is 120 pounds does not mean you need to air up to that.
Jim: I think that is what I said. Where we have it stored he adjsut the pressures.
He/they maintain a bunch of Mhs.
I may misspeak but I think he does use a table on pressures.
I don't know if he has weighed it. We haven't. I need to ask, if we ever take it out again. We used the information on the sticker behind Driver's seat when it had original tires.
We took about 250 lbs of tv out of the front cap, and could probably run a tad less.
JmR
โApr-06-2016 09:56 AM
โApr-06-2016 08:40 AM
