Microwave
barney12345
Microwave is not flush against rv wall, leans out? How can knI fix? Should I take it to a pro
2 REPLIES 2
Gonzo42
They tend to be a bit heavy due to the magnet within the magnetron tube which generates the microwaves. Try not to do it by yourself. It might only be that it caught on something in the cabinet and didn't fully insert, but you will most likely have to remove it to check it out.
MOTHER SHIP Winnebago View 24H (2007 Dodge Sprinter 3500 Chassis, 2008 Body)3.0 L M-B Diesel V6 bought used with 24K miles. Toad: ROCKY the Flying Squirrel.
donn0128
Microwaves are held in place by a mounting bracket on the back wall that they sit on and two screws through the bottom of the upper cabinet. Locate the two screws and check to be sure their tight.
