Sep-19-2015 12:55 PM
Sep-19-2015 03:27 PM
smkettner wrote:
When the engine has been off 24 hours and you are plugged in... measure the chassis battery voltage. 12.7 or less is not charging. 13.2+ is charging. System or not this will check the function.
Sep-19-2015 03:17 PM
Sep-19-2015 03:13 PM
Sep-19-2015 03:04 PM
Sep-19-2015 02:54 PM
Sep-19-2015 02:03 PM
MobileBasset wrote:
I can see why you would want all house batteries to be the same ( and all new at the same time) but if the engine is charging from a different source why does it matter if it (they) are a different type than the house?
Sep-19-2015 01:57 PM
Sep-19-2015 01:55 PM
Sep-19-2015 01:40 PM
bob_nestor wrote:
I wouldn't mix them but that's based on the little knowledge I picked up when I installed AGM batteries in my previous RV. The inverter/converter in it had different settings for the various types of batteries and I had to change its settings to match the Lifeline AGMs. I also bought an intelligent battery charger at the time and it has different settings for different types of batteries. That might be just marketing hype, but then again ... What little I could find in the manual seemed to indicate the optimal voltage levels used for charging were different for AGMs vs regular batteries.
Sep-19-2015 01:37 PM
2oldman wrote:
jars= batteries.
I'm not sure if your house and engine are connected.
Sep-19-2015 01:35 PM
Sep-19-2015 01:33 PM
pianotuna wrote:
Hi,
All batteries would be best to be the same. I would prefer 12 volt jars. AGM deep cycle still has a 50% limitation for depth of discharge. They do work well as starter batteries because of their low internal resistance.
If you don't camp below -20 c (-4 f) and have deep pockets consider using LI batteries for the house and for the starter. They can be taken safely down to just 20% state of charge, and they do not have to be recharged to 100% unlike lead acid chemistries.
Lifeline does a great AGM.
I just switched to used telecom batteries and am happy with the results.
Do add some solar if you boondock. If you don't--then you don't need to have four house batteries.
Sep-19-2015 01:10 PM
