โApr-13-2019 10:14 AM
โApr-17-2019 12:42 PM
Mile High wrote:FIRE UP wrote:I guess I'll do some crawling around first to see if its even bad first, before I start a big mess with a hose ๐
There are many, many posts on the cleaning of rear radiators. Some say they have success in doing it while it's still in the coach. Well, based on just how are coach is built, the surrounding area of the entire radiator/shroud/CAC/bracing/exhaust/trans cooler/and a whole lot more, I can't even get a syringe needle near my fins, much less a garden hose with any form of pressure. So, this is why I yank it out of there.
Scott
โApr-17-2019 12:36 AM
Scott
โApr-16-2019 09:08 AM
Mile High wrote:FIRE UP wrote:That is too funny on the pic! Once it hits the net, its public that is for sure. I put a picture on IRV2 and noticed it a month later as a lead photo on one of their articles, unfortunately for the "wrong way" to do something ๐Mile High wrote:FIRE UP wrote:
Oh by the way, we were carrying an '08 Honda GL 1800 Goldwing. While the bike was quite warm, I saw no detrimental effects. As for the coach engine getting warm, it was due to a fin-clogged radiator that I didn't know I had. That condition has since been remedied.
I heard about that fin clogging issue - slobber tube throwing some oil. I going to try to clean mine this spring just for grins
Mile High,
The fin clogging as you noted, was primarily caused by the slobber tube tip, that was too far under the coach. And, it emmited oily fumes which, collected on the CAC and radiator fins which, collected all the dust, debris, leaves, hay, trash bags, grass and anything else that the fan vacuumed up and forced into those fins.
Extend the slobber tube and make darn sure the correct amount of oil is placed in the engine at oil changes,( this primarily applies to C-7 engines with the correct oil pan) and, your fin clogging days are ALMOST ELIMINATED.
I say almost because, the EARTH is dirty. And, driving around on it with a diesel pusher, especially with a rear radiator, you're gonna still accumulate SOME dust, debris, hay etc. It's a given.
On another note, funny you should comment on that picture of the coach and swivel wheel trailer as potentially, possibly being your coach. When I had the Hydralift on ours, I'd taken many photos of it and showed lots of folks here and other RV forums.
Well, one or more of my pics made the circuit in many ways. Several years after I'd removed that Hydralift and moved on to other means of hauling the bike, I was looking in a Craigslist ad about a "Bike Hauler". I clicked on the ad and low and behold, there was a picture of OUR MOTORHOME, WITH OUR LIFT, SHOWING OUR GOLDWING!!!!
I have considered those swivel wheel trailers, many times. At present, we haul the bike on a Rampage lift/carrier in the back of our '11 GMC Sierra 1500 Extended Cab 4x4. It works great. But, we'd like to bring along our Jeep with the bike and, we can't do it because I've removed the Hydralift several years ago. Still might go the swivel wheel route yet.
Scott
It looks like Swivel Wheel has something that allows for a toad behind it - I haven't looked serious but it must be a real stout frame under the trailer to support that extended receiver.
Did you clean your radiator yourself, or have it done?
โApr-15-2019 02:59 PM
โApr-14-2019 01:04 PM
Mile High,
Scott
โApr-14-2019 12:53 PM
โApr-14-2019 09:55 AM
โApr-14-2019 09:52 AM
โApr-13-2019 11:28 PM
Mile High wrote:
Has anyone installed a motorcycle lift on a rear radiator coach? I'm just wondering if the heat from the radiator causes problems with the bike, and if the bike causes problems with airflow.
The previous owner of mine installed a CruiserLift, but maybe it didn't work out and that is why he traded - not sure.
โApr-13-2019 07:22 PM
Mile High wrote:I new a guy who put a HD 74 on one and when he got there it was a trail bike.
โApr-13-2019 06:18 PM
โApr-13-2019 06:13 PM
โApr-13-2019 03:25 PM
โApr-13-2019 01:03 PM
